Forum Topic - QNX machine hung state: (3 Items)
we have a primary and secondary system running QNX 6.3.0 sp3.
for some reason, the primary system was in a hung state, therefore the user could not log in to it through the GUI, but
the machine was pingable, although was not able to telnet or phindows to the machine. Also it was noted that the
failover to the backup system did not kick in (this is a fully functional setup with HAM).
the question is, are there any dump files that I can share with the qnx team, like in Windows, in order to understand
what put the system into a hung state. Ironically, couple of hours ago, there was a checkfile on the same machine,
therefore that should rule out any corruption issues.
Re: QNX machine hung state
can i get a reply on this ? any questions?
Hi, isn't an easy question to be answered ...
It's seems to me that a process or an interrupt  on Your system is consuming the most part
of Cpu time:  GUI , telnet and phindows simply do not have time to run .
Because Your machine responds to ping , Your blocking process should have a priority in the
range from telnet's priority (suppose 10) up to network driver (check it - suppose 21).
An idea to trace  the problem, You can write a process with an higher priority (>max) to capture
the system process state when in such condition,  so You may be able to detect the process
that is blocking Your system. You can arrage an hardware trigger to start such 'dumper' or
use a sw watch dog trigger if an haedware one is not available.
regards,
m. sangalli
