Forum Topic - sin:
sin
It was reported a while ago that using sin with -n would make it core dump.  Today I started updating our custom image
with the latest 6.4 to start testing it on our target hardware.  I was a bit surprise to see that M6 doesn't contain an
updated sin.
Note that I didn't try it yet, maybe the bug was in libc or some other component but i though I would let you guys knows
Re: sin
It has been fixed.  I think sin is not included in the ntocore.  You should
give up all sin, and embrace pidin, my son. :-)
Seriously, here's an updated version if you really need it.
> dump.  Today I started updating our custom image with the latest 6.4 to
> that M6 doesn't contain an updated sin.
> component but i though I would let you guys knows.
> http://community.qnx.com/sf/go/post7465
cburgess@qnx.com
Attachment: Text sin 143.49 KB
Re: sin
Nothing would please me better then to give up all sin father.  The dark side shall have me as a disciple until pidin
can provide all of the wisdom that sin possesses..
> > OSTech
> cburgess@qnx.com
Re: sin
What is pidin missing, in this case, my son?
For your penance, go read some stl template header files.
> should
> side shall have me as a disciple until pidin can provide all of the
> 6.4 to
other
>  > > _______________________________________________
>  > > OSTech
>  > cburgess@qnx.com
> http://community.qnx.com/sf/go/post7476
cburgess@qnx.com
Re: sin
When sin is run with no argument it show in a nice an concise way the memory usage of a process.  I have not find
anything similar with pidin.
It would also be great to be able to see the physical address of memory
allocated via /dev/zero ( physical memory )
I'm currently trying to get a machine with 8Gig working, I haven't found a way to detect if a drive has allocated dmable
 memore above 4Gig.
Is your heart fill with that much hatred?  Father, I will pray to the god of all gods to save you soul.  Say we all.
> > should
> > 6.4 to
> other
> >  > > OSTech
> >  > cburgess@qnx.com
> > OSTech
> cburgess@qnx.com
Re: sin
> memory usage of a process.  I have not find anything similar with pidin.
pidin pmem?  Admittedly it would be nice if it didn't show every thread...
> a way to detect if a drive has allocated dmable memore above 4Gig.
Ok, I'll think about that.
<insert duke nukem quip here>
> You
>  > > should
> dark
> it core
>  > > 6.4 to
> to see
>  > other
>  > >  > > OSTech
>  > >  > cburgess@qnx.com
>  > > OSTech
>  > cburgess@qnx.com
> http://community.qnx.com/sf/go/post7479
cburgess@qnx.com
Re: sin
Thanks.
Is it normal that it's almost twice as big as 6.3.2's sin.
Re: sin
> Thanks.
I striped it but it still 116K compare with 88K.
Re: sin
Did it get linked static somehow?
> You should
>  > Thanks.
> http://community.qnx.com/sf/go/post7523
cburgess@qnx.com
Re: sin
I'm assuming you are not asking me right?
