Re: possible performance lag with core affinities using _devctl()
09/24/2014 9:52 AM
post111867
Yes, open/_devctl/close is much more expensive than ThreadCtl
You're trying to prevent migrations?
On 2014-09-24, 4:00 AM, David Beberman wrote:
> We explicitly sets the CPU affinity on every thread switch, usually it narrows it down to the CPU the thread is
running on when a thread became RUNNING and it widens it to all CPUs before the thread becomes READY or BLOCKED. We see
that thread switch overhead on QNX is significantly higher than on Linux, one benchmarks runs 4x slower. We suspect
that the relatively complex affinity setting code might be the culprit, in particular the case in which _devctl() is
used.
> Is there any knowledge about known performance bottlenecks regarding this?
> I have attached a segment of our glue layer sources that use this call.
> The function showing the _devctl() usage is:
> "JAMAICA_LOCAL int jamaicaNativeQNXThread_runmask_get_and_set"
> Thanks,
> David Beberman
> aicas
> http://community.qnx.com/sf/go/post111862
