Re: Microseconds sleep on QNX
08/25/2014 11:34 AM
post111536
Mario Sangalli schrieb:
> Il 25/08/2014 15:54, Radoslaw Kudaj ha scritto:
>> Hi,
>> I need to generate microseconds sleep (in microseconds resolution) on QNX 6.6.0.
>> As time tick on the QNX system is 1 ms functions: "clock_nanosleep()" and
>> "nanosleep()" do not provide microseconds sleep accuracy.
>> Is there any other reliable method to sleep over such short period of time (other than nanospin() function which
consumes too much CPU)?
>> thank you for any help,
>> regards
> A reliable usleep may dependes by platform/CPU You are using and if
> You can allows or not a preemption during usleep .
> If Your system has an hardware timer available , you can use it to
> generate an
> interrupt for You and do works in ISR or just send a pulse to an
> interrupt thread.
> Or You can read the timer in a loop and exit after the desidered us are
> elapsed
Mario wrote:
"other than nanospin() function which consumes too much CPU)".
that means polling of a timer could not be a solution.
My proposal:
if your target system is x86 based go with the IRQ 8 (RTC) ... it should be available again with QNX 6.6.
If you are working with an non-x86 SoC, then have a look to its hardware resources for hardware timers.
Regards
--Armin
> (be sure to set Your thread priority in order to gain the desidered
> accuracy).
> M.
> http://community.qnx.com/sf/go/post111535
