Forum Topic - Beaglebone Pinmux issue: (4 Items)
I'm trying to figure out how to change a pin mode correctly. I tried these three methods but none works.
1. Change code in init_pinmux.c (included in the BSP) adding some lines like out32(conf_gpmc_ad6         , (MODE(7)));
2. mmap_device_io of the memory where's stored the conf register.
3. mmap_device_memory of the same memory region above.
In points 2 and 3 I'm then using in32 and out32 methods to read and write values, but they seem unfunctional.
Am I missing smth?
Thanks everybody!
Re: Beaglebone Pinmux issue
>>>in32 and out32 methods... seem unfunctional.
Are you running as root and calling this prior to access...?
ThreadCtl( _NTO_TCTL_IO, 0 );
Sure!  Actually I do a in32(reg) to see the initial state, do an out32(reg, val) with the value required, and another
in32(reg). The two calls to in32 return the same result.
The only solution I found so far is to change the pin muxing in u-boot and recompile it (+ re-upload to SD) every time.
That's awkward.
