PCIe to PCI converter with imx6sabre smart
05/07/2014 1:01 PM
post110197
i'm just trying to test QNX on my Freescale iMX6 Sabre Smart Devices board.
The boot is working, and all the rest seems ok.
Since i have to interface my mx6 to a PCI board, I connected a PCIe to PCI converter from PLX (the bridge chip is
PEX8112).
If i launch the utility pci -v the converter is recognized but not the slave PCI board connected to it.
Below I attach my result of pci -v command.
Any suggestion or comments?
Thanks so much
Best Regards
Simone
# pci -v
PCI version = 2.10
Class = Bridge (Host/PCI)
Vendor ID = 16c3h, Unknown
Device ID = abcdh, Unknown Unknown
PCI index = 0h
Class Codes = 060000h
Revision ID = 1h
Bus number = 0
Device number = 0
Function num = 0
Status Reg = 10h
Command Reg = 7h
Header type = 1h Single-function
Latency Timer = 0h
Cache Line Size= 0h
Primary Bus Number = 0
Secondary Bus Number = 1
Subordinate Bus Number = 2
Secondary Latency Timer = 0h
I/O Base = 10h
I/O Limit = f0h
Secondary Status = 0h
Memory Base = 100h
Memory Limit = 1e0h
Prefetchable Memory Base = fff1h
Prefetchable Memory Limit= 1h
Prefetchable Base Upper 32 Bits = 0h
Prefetchable Limit Upper 32 Bits = 0h
I/O Base Upper 16 Bits = 0h
I/O Limit Upper 16 Bits = 0h
Bridge Control = 0h
PCI Int Pin = NC
Interrupt line = 0
CPU Interrupt = 0h
Capabilities Pointer = 40h
Capability ID = 1h - Power Management
Capabilities = dbc3h - 0h
Capability ID = 5h - Message Signaled Interrupts
Capabilities = 180h - 0h
Capability ID = 10h - PCI Express
Capabilities = 42h - 8000h
Class = Bridge (PCI/PCI)
Vendor ID = 10b5h, PLX Technology, Inc.
Device ID = 8112h, PEX8112 x1 Lane PCI Express-to-PCI Bridge
PCI index = 0h
Class Codes = 060400h
Revision ID = aah
Bus number = 1
Device number = 0
Function num = 0
Status Reg = 10h
Command Reg = 4h
Latency Timer = 0h
Cache Line Size= 0h
Primary Bus Number = 1
Secondary Bus Number = 2
I/O Base = f0h
I/O Limit = 0h
Secondary Status = 220h
Memory Base = fff0h
Memory Limit = 0h
Prefetchable Memory Base = fff0h
Prefetchable Memory Limit= 0h
Bridge Control = 0h
PCI Int Pin = INT A
Interrupt line = 0
CPU Interrupt = 0h
Capabilities = 5a02h - 8000h
Capabilities = 80h - 0h
Capabilities = 71h - 0h
