RE: "License Warning" when booting
04/15/2008 2:19 PM
post6817
Hi Tim,
You're getting the warning because the diskboot (and other components) that
ship with the development environment are licensed, where it's not on the
runtime kit. While the warning won't prevent you from booting, to get rid of
it, you'll need to rebuild the image using the Runtime Kit.
In /x86/boot/build, there should be the qnxbasesmp.build file, and assuming
you've installed the multicore package (formerly the high end bundle), you
should be able to rebuild the image. If you haven't installed the multicore
package, you can do so by inserting the CD after boot up and executing
'qinst' according to the ancient rituals:
cd /
qinst d /fs/cd0/repository/qnx6-target-smp.tarx | tar -zx -f-
Hope this helps.
Cheers,
-Brian
> From: Tim Gessner [mailto:tim@deltacompsys.com]
> Sent: Tuesday, April 15, 2008 11 13
> To: ostech-core_os
> Subject: "License Warning" when booting
> I used the x86 Runtime Kit to install Neutrino 6.3.2 to my
> embedded PC. I have a valid runtime license which I entered
> and it works fine.
> I then built my own image (actually just used the smp build
> file within the IDE). The system boots fine but I get a
> warning "No valid commercial license found".
> I have searched with no success. I did notice a build file
> which "license" included (finstall.build), but I'm not sure
> what this does (and haven't found any documentation on it).
> What do I need to add/do to my image so that it recognizes my license?
> Thanx!
> Tim
> http://community.qnx.com/sf/go/post6810
Re: "License Warning" when booting
04/16/2008 2:35 PM
post6926
I still haven't solved the qinst problem, but after speaking with a QNX engineer the diskboot problem has been resolved.
The diskboot used on the runtime kit does not require licensing while the version installed with the IDE does. By
copying the version from the runtime installation over the IDE version and rebuilding the image all is well.
FYI...
