Forum Topic - ifs issue with M6 drop:
I built my first T2 system today.  I used exactly the "old" working ifs.bld.
I get:
Scanning flash at 0xC8040000 (1st 128KB sector)
Found image        @ 0xC8040000
Jumping to startup @ 0xC0031B80
Unable to access "/dev/ser1" (2)
Unable to access "/dev/fs0p0" (2)
Welcome to QNX 6.4.0
Unable to start "devc-pty" (2)
[+script] .script = {
    umask 0
    [pri=20] devc-serial -u1 -Fe 0x1000a000,20
    reopen /dev/ser1
    [pri=20] devf-nor -s0xc8040000,64m -R
    waitfor /dev/fs0p0
    display_msg Welcome to QNX 6.4.0
    [pri=20] devc-pty &
Are /dev device names or /proc/boot filesystem layouts changed in 6.4?
Is there a place to read about this?
dave
Re: ifs issue with M6 drop
They haven't changed.  Rather it would appear that your drivers haven't registered
their devices by the time the waitfor times out.  What would cause that though
is unknown at this time.  Are the device drivers your own?
> ifs.bld.
> I get:
>     umask 0
>     reopen /dev/ser1
>     waitfor /dev/fs0p0
>     [pri=20] devc-pty &
> Thanks
> dave
> http://community.qnx.com/sf/go/post6651
cburgess@qnx.com
The drivers for devc and devf are minor bsp variants of the QNX drivers tailors for our addressing, etc.  No big diff.
I was hoping it was something "easy"...  :-)
dave
RE: ifs issue with M6 drop
Well,  given that devc-pty didn't work either it's probably not specific to
your drivers.  It must be something simple somewhere...
What BSP was it - I'll check to see if there were any gotchas...
Colin
  _____
Sent: Fri 11/04/2008 7:35 AM
To: ostech-core_os
Subject: Re: ifs issue with M6 drop
dave
OSTech
http://community.qnx.com/sf/go/post6659
<http://community.qnx.com/sf/go/post6659>;
It should be common mode "something".
I put the 6.3.2 OS in the same image: same failure.
I put 6.3.2 built devc and devf drivers: same failure.
I am trying to see if the issue with _mcount_ in libc is causing a runtime failure.
(Below is a -static linkage which did not error prior to the M6 install)
  LD        platform/bin/symbols/embed
libc.so: undefined reference to `_mcount_'
mcount.o is missing in both the libcS.a and libc.a so it would not surprise me that my runtime linkage is failing with
no console (yet).
dave
> ifs.bld.
Well to start, you should have a waitfor /dev/ser1 to ensure that you don't
continue until the serial driver name has registered its path .. then do the
re-open.
Thomas
