Forum Topic - tracelogger:
tracelogger
It would be nice if when tracelogger is used in ring mode that it somehow keeps the process and thread names.
While I'm at it, may i suggest that all OS threads be given names, such that when you look at io-net/io-pkt, devb-eide
and so forth, we have a better idea of who's what;-)
- Mario
Re: tracelogger
Agreed.  It's not quite as simple as it sounds though.  We do have an ongoing project
to do this, but I don't know when it will see the light of day.
> that when you look at io-net/io-pkt, devb-eide and so forth, we have a
I've tried, I've tried.  But alas unless you want to call them "threadpool worker thread 1 etc etc"
I think io-net certainly could use it, but I believe that all threads in io-pkt are generic workers.
> - Mario
> http://community.qnx.com/sf/go/post6605
cburgess@qnx.com
Re: tracelogger
Using "thread pool worker thread 1 et etc" isn't half bad ;-)
RE: tracelogger
The other pitfall that we have with some of the frameworks outside of the
kernel is that we need to maintain backwards compatibility with versions of
the OS that don't have thread name support in them (although I'm guessing
there's probably a way to work around this).
The io-pkt stack does indeed have a "one thread fits all" model that helps
to boost performance by transitioning between handling hardware directly
into stack processing without a context switch, so naming them wouldn't
really mean that much unless we constantly "renamed" them on the fly (and we
don't think that the performance impact that we'd get rally justifies that
	Robert.
From: Mario Charest [mailto:mcharest@zinformatic.com]
Sent: Thursday, April 10, 2008 11:09 AM
To: ostech-core_os
Subject: Re: tracelogger
io-
OSTech
http://community.qnx.com/sf/go/post6625
RE: tracelogger
> From: Robert Craig [mailto:rcraig@qnx.com]
> Sent: April 10, 2008 1:02 PM
> To: ostech-core_os
> Subject: RE: tracelogger
> outside of the kernel is that we need to maintain backwards
> compatibility with versions of the OS that don't have thread
> name support in them (although I'm guessing there's probably
The flash player just looks up pthread_setname_np et al using dlsym and uses
them if it finds them.  In theory one should just have to declare the
symbols to be weak and not call them if they're NULL but that appears not to
work.
