Forum Topic - ClockCycles() use in interrupt handlers:
ClockCycles() is listed in docs as "unsafe" to call from an interrupt handler.  However, for interrupt latency tests,
there seems to be no "safe" call for a precise timestamp.
Also release notes for 6.2.1B list "Execution of ClockCycles() inside an interrupt causes kernel crash (Ref# 14369)" as
having been fixed, i.e. it must have been a valid use case.
Why is it listed as unsafe?  Does it re-enable interrupts on exit?
Thanks.
Re: ClockCycles() use in interrupt handlers
I've been using ClockCycles() from the context of the clock interrupt
handler since 2004.
> handler.  However, for interrupt latency tests, there seems to be no
> interrupt causes kernel crash (Ref# 14369)" as having been fixed, i.e.
> Thanks.
> http://community.qnx.com/sf/go/post5816
>   However, for interrupt latency tests, there seems to be no "safe" call for a
>  precise timestamp.
> interrupt causes kernel crash (Ref# 14369)" as having been fixed, i.e. it must
> Thanks.
It's safe on x86 as for the other platform I don't know
It's probably safe only on HW which has rdtsc opcode.
When this opcode is missing, it crashes the kernel.
PKY
AW: ClockCycles() use in interrupt handlers
Looking at the implementations in
  /usr/include/<platform>/neutrino.h
it looks like there are interrupt-safe implementations of ClockCycles()
for all platforms except for the ARM (i.e., mips, ppc, sh, and x86).
I guess a function is listed as "unsafe" as long as we cannot guarantee
that the implementation will be [interrupt]-safe on /all/ platforms...
Oh, and the bit about re-enabling interrupts would only be true for
kernel calls -- and those exactly you must avoid by all means in an
interrupt handler (the handler was itself invoked by the kernel; doing
a kernel-call would introduce a reentrancy we cannot handle at that
point). The inline-assembly-implementations of ClockCycles on non-arm-
platforms all just read some special CPU registers and maybe do a tiny
bit of calculation; so there's no need to call kernel there.
Hope this helps,
- Thomas
> -----Ursprüngliche Nachricht-----
> Von: Dennis Kelly
> Gesendet: 14 March 2008 16:44
> An: ostech-core_os
> Betreff: ClockCycles() use in interrupt handlers
> 14369)" as having been fixed, i.e. it must have been a valid use case.
> Thanks.
The documentation is wrong. ClockCyles() is safe to use in all environments
on all architectures. The kernel instrumentation wouldn't work if that
wasn't true.
> Hope this helps,
> - Thomas
> > Von: Dennis Kelly
> > An: ostech-core_os
> > Thanks.
> > OSTech
> http://community.qnx.com/sf/go/post5850
Thanks.  It would be good if we get the docs fixed for 6.4.
RE: ClockCycles() use in interrupt handlers
Dennis,
Can you please file a PR then? That's the best way to ensure it gets fixed.
Cheers,
-Brian
> From: Dennis Kellly [mailto:dkelly@qnx.com]
> Sent: Monday, March 17, 2008 08 53
> To: ostech-core_os
> Subject: Re: ClockCycles() use in interrupt handlers
> http://community.qnx.com/sf/go/post5854
Re: RE: ClockCycles() use in interrupt handlers
I've corrected the docs.
since when?
I remember, that "rdtsc" instructions were emulated on 386/486 cpu's by "wrong opcode exceptions" using the PIT. This
did "not" work in ISR's.
If this has been changed, can someone tell me the 1st QNX Version, which can use ClockCycles in ISR's on 386/486?
-Michael
> wasn't true.
> > Hope this helps,
> > - Thomas
> > > Von: Dennis Kelly
> > > An: ostech-core_os
> > > Thanks.
> > > OSTech
> > OSTech
environments
> since when?
"wrong opcode exceptions" using the PIT. This did "not" work in ISR's.
I don't know what version it went out in, but the bug fix was implemented
in January of 2003.
	Brian
