03/12/2008 6:04 AM
post5725
Hi all,
This is my first post here, so don't know if this is the correct place, but since this is a severe problem any place
should be ok ;)
In our project we have a process which has one thread sending messages to another process which is receving messages and
pulses from different other processes. once in a while a message does not get send correctly. I added traceevents in
the code we use and filled in some fixed values in our header to clarify the problem. The system must be under heavy
load for it to occur, more logging and more tracing seems to increase the change of it to happen.
below the code and traces made, first is the successfull send (dummy=0x000e1b0e) second is the failed send (dummy=
0x000e1b0f)
@t:0xe55eccca one can see the MSG_SENDV/11 does send a message containing our dummy value correct
in the failed send
@t:0xe570fc8a the dummy value does not appear and an incorrect message is send.
My question is:
is it be possible that msgsendvs sometimes sends an incorrect message? wrongly reads the IOV structure, or ....
I am clueless on what to do next since I could not reproduce the problem with a simple test program(just sending and
receiving), but only in our system which is under heavy load (60% average cpu usage)
I hope this information is sufficient if there are any questions please ask.
Kind regards,
Erwin Chabot
<versioninfo>
TRACEPRINTER version 1.02
TRACEPARSER LIBRARY version 1.02
-- HEADER FILE INFORMATION --
TRACE_FILE_NAME:: /root/tracefinal
TRACE_DATE:: Wed Mar 12 10:38:00 2008
TRACE_VER_MAJOR:: 1
TRACE_VER_MINOR:: 01
TRACE_LITTLE_ENDIAN:: TRUE
TRACE_ENCODING:: 16 byte events
TRACE_BOOT_DATE:: Tue Mar 11 17:24:13 2008
TRACE_CYCLES_PER_SEC:: 2392482800
TRACE_CPU_NUM:: 1
TRACE_SYSNAME:: QNX
TRACE_NODENAME:: I2
TRACE_SYS_RELEASE:: 6.3.2
TRACE_SYS_VERSION:: 2006/03/16-14:19:50EST
TRACE_MACHINE:: x86pc
TRACE_SYSPAGE_LEN:: 2280
</versioninfo>
<mycode>
//fill the header with some values to show up in the traces
//message is a union of a _pulse type and our header type
message.header.type = 1234;
message.header.system = 0x56;
message.header.align = 0x78;
message.header.dummy = dummy;
message.header.sizeRequest = sizeRequestData;
// trace dummy, requestid and processid
TraceEvent(_NTO_TRACE_INSERTSUSEREVENT, 111, pConnection->channelId, dummy );
TraceEvent(_NTO_TRACE_INSERTSUSEREVENT, 111, pConnection->channelId, requestId );
TraceEvent(_NTO_TRACE_INSERTSUSEREVENT, 111, pConnection->channelId, getpid() );
// fill IOV struct and send the message
SETIOV(&iov[0], &message, sizeof(message.header));
SETIOV(&iov[1], pRequestData, sizeRequestData);
int result = MsgSendvs(channelId, iov, 2, pReplyData, sizeReplyData);
</mycode>
<successfull>
t:0xe55eb12e CPU:00 KER_EXIT:TRACE_EVENT/01 ret_val:0x00000000 empty:0x00000000
t:0xe55eb9ea CPU:00 USREVENT:EVENT:111, d0:0x4000000b d1:0x000e1b0e
t:0xe55ebf2a CPU:00 USREVENT:EVENT:111, d0:0x4000000b d1:0x00000005
t:0xe55ec68a CPU:00 USREVENT:EVENT:111, d0:0x4000000b d1:0x0099703f
t:0xe55eccca CPU:00 KER_CALL:MSG_SENDV/11
coid:0x4000000b
sparts:2
rparts:0
msg:"" (0x78561234 0x000e1b0e 0x00000008)
t:0xe55ed60a CPU:00 COMM :SND_MESSAGE rcvid:0x0000000e pid:10055729
t:0xe55ee2fe CPU:00 THREAD :THREPLY pid:10055743 tid:1 priority:15 policy:2
t:0xe55ee6a2 CPU:00 THREAD :THRUNNING pid:10055729 tid:2 priority:15 policy:2
t:0xe55eea8a CPU:00 COMM :REC_MESSAGE rcvid:0x0000000e pid:10055729
t:0xe55ef306 CPU:00 KER_EXIT:MSG_RECEIVEV/14
rcvid:0x0000000e
rmsg:"" (0x78561234 0x000e1b0e 0x00000008)
info->nd:0
info->srcnd:0
