Kernel trace : dynamic filtering : event handler restrictions
02/24/2012 5:59 AM
post91764
Hello QNX Developers,
As I understand from docs, I can attach event handling routine via TraceEvent (_NTO_TRACE_ADDEVENTHANDLER, ...) and it
will be called by the kernel directly.
1) What are the stack restrictions ?
2) How much of process address space is mapped ?
Can I affect it in any way ?
Example code from QNX documentation accesses process global variable, so I assume that at least
some part of process address space is mapped.
In case of complete address space is mapped, then may be it makes
sense to keep the size of the executable implementing dynamic kernel event filtering
as small as possible...
Thank you!
