Forum Topic - benchmark runs slow on PPC, but ok on x86:
This benchmark runs on Neutrino about the same as it does on Linux on x86, but it (appears that it) runs much more
slowly on PPC.
I took a quick look at the code, and I don't see a reason.
Anyone see what the difference might be?
Keith
Attachment: Text stream.c 11.46 KB
Re: benchmark runs slow on PPC, but ok on x86
but it (appears that it) runs much more slowly on PPC.
What PPC chip are you running it on?
I'm running on a AMCC PPc440epx.
The initial Book E processors did not have hardware floating point,
so there was no support added to procnto-booke (since we couldn't test
it). Once there was a CPU with FPU hardware, we added support to procnto,
but I'm not sure if it's been made available as a patch yet. Check the
output of "pidin info". If the string "FPU" does not appear at the end of
the
second line, you're not using the hardware for floating point operations,
which will explain your slowdown.
	Brian
Thanks Brian,
It appears I am not using the FPU.  Who can I talk to about finding the status of the patch for running the AMCC440epx
FPU?
Best regards,
Keith
> status of the patch for running the AMCC440epx FPU?
I can't see the patch accessable anywhere, so probably the best person
is your sales rep.
	Brian
