Forum Topic - Generic notification of process death - why not?:
I'm pretty sure this has been asked before, but I cannot find the answer.
In QNX4, a process could set the _PPF_INFORM process flag to receive a message from the kernel whenever any process died
In QNX6, there is no such mechanism any longer - at least not for being informed of the death of _any_ process for _any_
 reason. We can only get notification under certain conditions - for session 1, for child processes, for client
processes connected to us, or for processes terminating abnormally.
Is there a specific reason that the process manager does not provide a generic process death notification mechanism? If
so, what is that reason?
Thanks in advance,
Thomas
Re: Generic notification of process death - why not?
This might shed some light as to why it isn't supported anymore:
http://www.qnx.com/developers/qnx4/qnx4kb/solution.html?code=9414
Finally this might be an interesting workaround:
http://www.qnx.com/developers/docs/6.3.0SP3/neutrino/prog/process.html#id24
RE: Generic notification of process death - why not?
Hi Gervais,
all nice and jolly, but I was talking about __all__ process terminations,
not only, for example, the crashes (abnormal terminations).
A simple pulse could have done, with the pulse value being the process id.
Cheers,
Thomas
From: Gervais Mulongoy [mailto:community-noreply@qnx.com]
Sent: Montag, 7. November 2011 14:59
To: ostech-core_os
Subject: Re: Generic notification of process death - why not?
OSTech
http://community.qnx.com/sf/go/post89900
Again as a workaround, you could use a starter process that registers
the pathname /proc/starter, fork()s and exec()s the chosen binary and
finally calls wait(). Starter would be like a replacement for the on
utility.
AW: Re: Generic notification of process death - why not?
Gervais, that is _not_ my question. My question is what the reason was to not implement a generic mechanism.
- Thomas
----- Originalnachricht -----
Von: Gervais Mulongoy [mailto:community-noreply@qnx.com]
Gesendet: Monday, November 07, 2011 09:19 AM
An: ostech-core_os <post89903@community.qnx.com>
Betreff: Re: Generic notification of process death - why not?
utility.
OSTech
http://community.qnx.com/sf/go/post89903
RE: Re: Generic notification of process death - why not?
How is the kernel supposed to know what event to send?  Like with procmgr_event_notify(), the event would have to be
given to the kernel, and then MsgDeliverEvent() invoked when the process exits.  The problem then, is that the server
delivering the message does not know what the message is, and cannot take a chance to modify it, so there's no place to
store the PID of the exiting process.  The best that could happen is you would get your event on every process death,
and would then have to scan to determine which PID.
> From: Thomas Haupt [mailto:community-noreply@qnx.com]
> Sent: November-07-11 11:07 AM
> To: ostech-core_os
> Subject: AW: Re: Generic notification of process death - why not?
> - Thomas
> Again as a workaround, you could use a starter process that registers the
> pathname /proc/starter, fork()s and exec()s the chosen binary and finally
> calls wait(). Starter would be like a replacement for the on utility.
> http://community.qnx.com/sf/go/post89913
AW: RE: Re: Generic notification of process death - why not?
I had figured that since we deliver specific pulses on various occasions (e.g., thread death) something like that would
have been possible for processes as well. But I see your point - it's a bit tricky, architecturally.
Von: David Sarrazin [mailto:community-noreply@qnx.com]
Gesendet: Monday, November 07, 2011 11:09 AM
An: ostech-core_os <post89915@community.qnx.com>
Betreff: RE: Re: Generic notification of process death - why not?
> To: ostech-core_os
> - Thomas
OSTech
http://community.qnx.com/sf/go/post89915
Hi Thomas,
What about using TraceEvent()?   You could listen for _NTO_TRACE_PROCESS class messages to monitor process creation and
destruction.
-Will
I've even thought of that, but consider it quite a hack... Though _that_ would work. Still, it doesn't explain my
original question...
Von: Will Miles [mailto:community-noreply@qnx.com]
Gesendet: Monday, November 07, 2011 09:32 AM
An: ostech-core_os <post89906@community.qnx.com>
Hi Thomas,
destruction.
-Will
OSTech
http://community.qnx.com/sf/go/post89906
