Forum Topic - Intel Advanced Vector Extensions Support (AVX): (7 Items)
Hi
I have an Intel Sandy Bridge-based system up-and-running...
(cf. topic: http://community.qnx.com/sf/discussion/do/listPosts/projects.bsp/discussion.bsp.topc20053)
I decided to try out some AVX instructions and wrote a small program that uses AVX intrinsics... but my program keeps
crashing in Momentics (SIGILL "illegal instruction").
I figure this is due to the OS not supporting the AVX instruction set yet.
Wikipedia says on its AVX page: "AVX adds new register-state through the 256-bit wide YMM register-file, so explicit
operating system support is required to properly save & restore AVX's new registers between context switches."
Now my question (for the kernel team?):  (When) will Neutrino support this instruction set? Is there a roadmap for this?
Lorenz
Re: Intel Advanced Vector Extensions Support (AVX)
> Hi
>  AVX intrinsics... but my program keeps crashing in Momentics (SIGILL "illegal
>  instruction").
> bit wide YMM register-file, so explicit operating system support is required
Just an educated guess.  If this is like floating point instruction, OS support is only needed if you have more then one
 thread using this.  You may be running into other issue like alignment (xmm stuff is picky).  To test this theory, have
 your program disable all interupt, run a highest priority and not make any kernel calls during the calculations and see
 if the crash still occurs. If it does then it most likely NOT an OS issue.
> Thanks,
> Lorenz
Hmmm... thanks for your input.
I tried running my program at highest priority, but I don't think that's the issue, since the program already crashes
when trying to execute the first AVX intrinsic...
My complete test program:
#include <iostream>
#include <immintrin.h> // AVX instrinsics
int main( int argc, char** argv )
 	__m256 var;
	__m256 var2;
	__m256 result;
	var = _mm256_set1_ps(1.f);
	var2 = _mm256_set1_ps(3.f);
	result = _mm256_add_ps(var,var2);
	return 0;
Doesn't get any simpler than that...
Mario Charest wrote:
>> Hi
>>   instruction").
>> to properly save&  restore AVX's new registers between context switches."
one thread using this.  You may be running into other issue like alignment (xmm stuff is picky).  To test this theory,
have your program disable all interupt, run a highest priority and not make any kernel calls during the calculations and
 see if the crash still occurs. If it does then it most likely NOT an OS issue.
The AVX extension must be enabled by the kernel or driver ... also the
libc must support the AVX extension (dynamic linker ..)
You need also the version 4.4.2 of gcc ...
--Armin
I'm using 4.4.2 (SDP 6.5.0, IDE 4.7) ...  the compiling and linking of the test program in my previous post works
without a problem..  Don't know about libc version, but from what I found, glibc 2.11 onwards has AVX support.
The issue is definitively in the kernel IMO... it's not AVX enabled yet.
These are AVX modifications done in 2009 for the linux kernel, for example:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=a30469e7921a6dd2067e9e836d7787cfa0105627
I confess I don't know what I'm talking about, but I would think something similar would have to be done in the Neutrino
 Kernel..?
Lorenz,
forget AVX for QNX6. QSS need their power to fight against Android and
~300000 Android apps. They are focused on "Arm" ... no time left for
x86, IMHO.
--Armin
Neutrino Kernel..?
> http://community.qnx.com/sf/go/post85256
RE: Intel Advanced Vector Extensions Support (AVX)
QNX remains focused on our core offerings
http://www.qnx.com/products/neutrino-rtos/index.html
AVX support is a requirement for the next release.
Chris
From: Armin Steinhoff [mailto:community-noreply@qnx.com]
Sent: April-29-11 3:35 AM
To: ostech-core_os
Subject: Re: Intel Advanced Vector Extensions Support (AVX)
Lorenz,
x86, IMHO.
--Armin
the
the test program in my previous post works without a problem..  Don't
AVX support.
yet.
example:
something similar would have to be done in the Neutrino Kernel..?
OSTech
http://community.qnx.com/sf/go/post85312
