02/05/2008 3:29 PM
post4816
> We believe that we have located the problem. It appears to lie within the io-
> blk.so code.
> When the blk ramdisk=xxx option is used, a path has been found where a
> ramdisk's buffer can be cleaned when invalidated. When using the ramdisk (not
> to be confused with devb-ram), the buffers should not be cleaned when
> invalidated. In the case of this forum's thread, this eventually leads to
> crashing the devb-eide driver.
> Until fixed, the suggested workaround is to use devb-ram instead of using the
> blk ramdisk=xxx option with devb-eide or the other devb-xxx drivers.
> Peter Mitsis
Just want to confirm that not using the ramdisk (devb-eide) solved the crashing problem for us.
Thanks.
