Forum Topic - Adding trace events into the kernel :
I like to get a more detailed System Profiling information about the time spend in the kernel. What’s the best approach
 to add some time stamps for example.
A TraceEvent() call of type user event doesn’t work.
Re: Adding trace events into the kernel
Hi Soenke,
Can you elaborate a bit on what you are trying to do, and what you have already tried?
Cheers,
Colin
> time spend in the kernel. What’s the best approach to add some time
> stamps for example.
> http://community.qnx.com/sf/go/post4615
cburgess@qnx.com
I've noticed bad message passing performance with certain messages sizes on a MPC8313. 1k messages arer slower than 2k
messages.
I've captured this in a kev file. But I just see that going from "Send message" state to "Reply blocked" takes 37 usec
in the 1k case and < 10usec for 2k messages. See attachment.
I'm wondering, if I can dig more deaply into the problem by adding trace stamps into the kernel.
Sönke
Attachment: Image SystemProfiler.JPG 145.89 KB
> on a MPC8313. 1k messages arer slower than 2k messages.
> message" state to "Reply blocked" takes 37 usec in the 1k case and < 10usec
You could but you can't use TraceEvent() to do it ... it is a kernel call
and you are already in the kernel (assuming
you are instrumenting the message pass code), you would need to use the
internal trace_* calls in ker_trace or
nano_trace.
However, adding code into the message copy path will have a measurement
effect.  What I'd do first is to use
the trace to look at the overall scenario:
* Length of data/message
* State of receiver
* Length of READY queue's
.. etc
This will allow you to take a first look at the code and understand how the
code path differs in both scenarios
that you are tracing.
Thomas
