io-graphics command-line options
01/21/2008 1:28 PM
post4476
What are the correct command line options to bring up devg-flat in 320x240x8 with a 128k frame buffer at 0x0ffe8000.
Assume HW and palette is already configured.
I've tried both old and new param styles, but can't seem to pass the correct address to devg-flat.
Here's what I tried:
io-graphics -d flat xres=320,yres=240,bitpp=8,photon,amem=0x0ffe8000,0x20000 -pphoton
also
io-graphics -d flat xres=320,yres=240,bitpp=8,photon,mem_opts=0x0ffe8000,0x20000 -pphoton
Note: the documentation is inconsistent wrt amem/mem_opts (see docs and usage for io-graphics and devg-flat)
In both cases, io-graphics terminates cleanly with the following slog info:
-- Unable to construct generic mode number
-- PCI attach failed!
-- mem_init: No such file or directory
-- fontserver: clean
-- Received terminate request, exiting - EOK
I hacked up devg-flat and created devg-flat_myaddr and tried again without amem/mem_opts and it works fine.
What am I missing?
Second question:
I want rotate the screen by 180. What are the correct command line option?
Note: The documentation is inconsistent wrt chaining hook (see io-graphics docs and usage). Is it a quoted string with
spaces or unquoted with colons?
I tried the following:
io-graphics -d flat_myaddr hook="devg-rotate90.so devg-rotate90.so" xres=320,yres=240,bitpp=8,photon -pphoton
It loads, no unexpected slogger msgs, but doesn't touch the frame buffer.
-david
