Forum Topic - Small for loop time is not deterministic: (5 Items)
Hi
I found something strange on my application on my Power PC.
The example is really simple read clockcycles, do a forloop and read clock cycles again.
And after this save min and max. (See attached code).
The question is why this time not is really deterministic?
It does the same thing every time...
Program running at priority 100 and nothing else execute with high priority running on target.
Output from program:
Min 61
Max 2585
Min 61
Max 9533
Min 61
Max 3377
Min 61
Max 3303
My target is a Freescale PowerPC 600Mhz.
Running QNX 6.5.0
And BSP MPC8379RDB
Regards
/Lasse
Attachment: Text TEST_FOR.c 1.06 KB
RE: Small for loop time is not deterministic
It can be preempted at any point even you are running at prio 100, such
as interrupt.
Lichun
From: Lasse Skov [mailto:community-noreply@qnx.com]
Sent: Wednesday, October 06, 2010 10:19 AM
To: ostech-core_os
Subject: Small for loop time is not deterministic
Hi
clock cycles again.
Min 61
Max 2585
Min 61
Max 9533
Min 61
Max 3377
Min 61
Max 3303
Running QNX 6.5.0
And BSP MPC8379RDB
Regards
/Lasse
OSTech
http://community.qnx.com/sf/go/post69745
> -----Message d'origine-----
> De : Lasse Skov [mailto:community-noreply@qnx.com]
> Envoyé : 6 octobre 2010 10:19
> À : ostech-core_os
> Objet : Small for loop time is not deterministic
> Hi
> cycles again.
> running on target.
> Min 61
> Max 2585
> Min 61
> Max 9533
> Min 61
> Max 3377
> Min 61
> Max 3303
Are these value in ClockCyles ( not scaled to ns, us  or ms ?). I would suspect it's caused by interrupts plus effect of
 flush caching etc.  On PowerPC I suspect the value is NOT in clock cycles ( as on x86 ) hence you are measuring with
less precision, and you loops execute asynchronously to that.
> Running QNX 6.5.0
> And BSP MPC8379RDB
> Regards
> /Lasse
Re: RE: Small for loop time is not deterministic
> suspect it's caused by interrupts plus effect of flush caching etc.  On
>  measuring with less precision, and you loops execute asynchronously to that.
Yes these value is in raw ClockCycles.
> are
Also not scaled to ns, us...
But the function not return exact number of clock cycles.
SYSPAGE_ENTRY(qtime)->cycles_per_sec return 100000500 on my PPC
