Forum Topic - x86 image on usbstick:
My goal is to crate qnx image that I can put on usbstick and boot it using grub.
The image is not directly installed to /dev/usb but I want it to put raw file on a vfat formated pendrive.
Using in grub
title QNX_rtl
        kernel /boot/memdisk.bin
        initrd /boot/qnx.raw
I have tried with all this
bios.build
finstall.build
qnxbasedmaaps.build
qnxbasesmp.build
qemu-minimal.build
qnxbase.build
qnxbasedma.build
and they all boot fine in QEMU but neither wants to boot in real PC from grub and pendrive
They boots almost fine but stops after
 Hit Esc for .altboot............................................................
What could be fix for booting qnx with my method?
Re: x86 image on usbstick
Post you project file or post the non-momentics version of the mkifs file.
Are you using:
[virtual=x86,bios] .bootstrap={   ?
try:
[virtual=x86,raw] .bootstrap={
Maybe this helps.
Check also:
http://www.qnx.com/developers/docs/6.3.2/neutrino/utilities/m/mkifs.html#raw
Freddy
I
Just for reference, I'm doing exactly this at the moment using the following configuration:
menu.lst
title QNX USB Image (generic.ifs)
        root (hd0,0)
        kernel /generic.ifs
build file:
[virtual=x86,elf +compress] .boot {
// blah blah
I believe it's the elf bit which is most crucial here.  Once I've created a generic.ifs from this build file I simply
drop it on the USB stick and I'm off. Very handy!
