Forum Topic - QNX6 boot loader:
QNX6 boot loader
Is there any clean way to modify the boot message on a QNX6 filesystem, in other words, something like dinit's -m option
, but for mkqnx6fs?
lew
Re: QNX6 boot loader
  I don't think there is a "clean" way, but if you don't mind getting
your hands a tad dirty you can potentially get the boot sector, and
modify the string manually (using a hex editor for example), the string
21 bytes long (including the null at the end). Once you are satisfied
with the changes, update the old bootsector with your new one (you could
probably reuse that bootsector on future installs but I haven't tried
any of this).
If you have a virtual machine handy you should experiment this one so
you can comfortable with the process. The tool of choice for this type
of work is the 'dd' utility. An example of getting the first 512 bytes
of a partition:
dd if=/dev/hd1t179 of=bootsector bs=512 count=1
A nice utility shipped with QNX Neutrino is called 'spatch' which you
can use to edit the the bootsector search for the string "QNX v1.2b Boot
Loader" and change it to say what ever you want (within the 20 byte
limit, the 21st byte is a null so leave it there).
Sorry there is no easier way that I presently know of to do what you asked.
Good luck!
option, but for mkqnx6fs?
> Thanks,
> lew
> http://community.qnx.com/sf/go/post61711
