PCIe board doesn't work with PCI-BIOS V2
07/19/2010 5:10 AM
post59782
the PCIe interface of our PROFIBUS board has been recognised by all PCI-BIOS versions prior
PCI-BIOS V2 !
Are you excluding again 80% of all PCI interfaces which have a class code of UNKNOWN ?
Here is the pci -vv output with PCI-BIOS V2:
Class = Unknown (Unknown)
Vendor ID = 10b5h, PLX Technology, Inc.
Device ID = 86e1h, Unknown Unknown
PCI index = 0h
Class Codes = ff0000h
Revision ID = ach
Bus number = 7
Device number = 4
Function num = 0
Status Reg = 2b0h
Command Reg = 17h
I/O space access enabled
Memory space access enabled
Bus Master enabled
Special Cycle operations ignored
Memory Write and Invalidate enabled
Palette Snooping disabled
Parity Error Response disabled
Data/Address stepping disabled
SERR# driver disabled
Fast back-to-back transactions to different agents disabled
PCI INTx enabled
Latency Timer = 20h
Cache Line Size= 10h un-cacheable
BAR - 0 [Mem] = f0280000h 32bit length 512 enabled
BAR - 1 [I/O] = 2000h length 256 enabled
BAR - 2 [Mem] = f0200000h 32bit length 524288 enabled
Subsystem Vendor ID = 14a0h
Subsystem ID = 2bh
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 5
CPU Interrupt = 5h
Capabilities Pointer = 40h
Capability ID = 1h - Power Management
Capabilities = 0h - 0h
Capability ID = 6h - CompactPCI Hot Swap
Capabilities = 0h - 3h
Capability ID = 3h - VPD
Device Dependent Registers:
0x040: 0148 0000 0000 0000 064c 0000 0300 0000
0x050: 0000 0000 0000 0000 0000 0000 0000 0000
0x0f0: 0000 0000 0000 0000 0000 0000 0000 0000
--Armin
