Forum Topic - mips fpu context: (5 Items)
mips fpu context
Could someone confirm how are FPU registers laid out in MIPS
context?
The logic that used to be coded in gdb assumes something
that doesn't work. With the logic I am going to describe it
works, but I am not sure if it is of generic value, or it
just happens to work with the two targets I was testing with.
In the context, we reserve 32 8-byte values to store FPU
register values. Mips has 16 8-byte regs or 32 4-byte float
registers. When used as double, then even+next odd comprise
singe double value.
The logic that used to be in gdb calculated offset as
regno * 8
and on big endian systems, it would add 4.
However, that doesn't work. What works is this:
(regno & ~1) * 8    (i.e. calculate offset of closest
previous even regno)
then:
On big endian:
	for even regno, add 4.
On little endian:
	for odd regno, add 4.
This effectively means that every odd-indexed 8-byte value
in our context is unused which seems strange.
Is this new logic correct, or are there other gotchas?
Aleksandar
Re: mips fpu context
Here's the code that stores the context (t2 is pointing at a
MIPS_FPU_REGS structure).
	cfc1	t1,$31
	sdc1	 $f0, 0*8(t2)
	sdc1	 $f1, 1*8(t2)
	sdc1	 $f2, 2*8(t2)
	sdc1	 $f3, 3*8(t2)
	sdc1	 $f4, 4*8(t2)
	sdc1	 $f5, 5*8(t2)
	sdc1	 $f6, 6*8(t2)
	sdc1	 $f7, 7*8(t2)
	sdc1	 $f8, 8*8(t2)
	sdc1	 $f9, 9*8(t2)
	sdc1	$f10,10*8(t2)
	sdc1	$f11,11*8(t2)
	sdc1	$f12,12*8(t2)
	sdc1	$f13,13*8(t2)
	sdc1	$f14,14*8(t2)
	sdc1	$f15,15*8(t2)
	sdc1	$f16,16*8(t2)
	sdc1	$f17,17*8(t2)
	sdc1	$f18,18*8(t2)
	sdc1	$f19,19*8(t2)
	sdc1	$f20,20*8(t2)
	sdc1	$f21,21*8(t2)
	sdc1	$f22,22*8(t2)
	sdc1	$f23,23*8(t2)
	sdc1	$f24,24*8(t2)
	sdc1	$f25,25*8(t2)
	sdc1	$f26,26*8(t2)
	sdc1	$f27,27*8(t2)
	sdc1	$f28,28*8(t2)
	sdc1	$f29,29*8(t2)
	sdc1	$f30,30*8(t2)
	sdc1	$f31,31*8(t2)
	sw		t1,REG_FPCR31(t2)
On Thu, Apr 01, 2010 at 02:45:38PM -0400, Aleksandar Ristovski wrote:
> Hello,
> context?
> singe double value.
> regno * 8
> then:
> On big endian:
> On little endian:
> Thanks,
> Aleksandar
> http://community.qnx.com/sf/go/post51070
sdc1 is 64-bit store which matches what I am observing (full
double value is stored at even-indexed locations).
The book mentions 32-bit and 64-bit cpus. The code snippet
(using sdc1 on odd-numbered fp registers) suggests the code
is for 64-bit cpus.
Shouldn't we have two different snippets, one for 32 bit
which would use swc1 instructions to store 4 bytes of each
fp register, and another version which would use sdc1 as it
does now?
Or, how can I detect which flavour is in question: 32-bit or
64-bit FP registers?
Aleksandar
> 	cfc1	t1,$31
> 	sdc1	 $f0, 0*8(t2)
> 	sdc1	 $f1, 1*8(t2)
> 	sdc1	 $f2, 2*8(t2)
> 	sdc1	 $f3, 3*8(t2)
> 	sdc1	 $f4, 4*8(t2)
> 	sdc1	 $f5, 5*8(t2)
> 	sdc1	 $f6, 6*8(t2)
> 	sdc1	 $f7, 7*8(t2)
> 	sdc1	 $f8, 8*8(t2)
> 	sdc1	 $f9, 9*8(t2)
> 	sdc1	$f10,10*8(t2)
> 	sdc1	$f11,11*8(t2)
> 	sdc1	$f12,12*8(t2)
> 	sdc1	$f13,13*8(t2)
> 	sdc1	$f14,14*8(t2)
> 	sdc1	$f15,15*8(t2)
> 	sdc1	$f16,16*8(t2)
> 	sdc1	$f17,17*8(t2)
> 	sdc1	$f18,18*8(t2)
> 	sdc1	$f19,19*8(t2)
> 	sdc1	$f20,20*8(t2)
> 	sdc1	$f21,21*8(t2)
> 	sdc1	$f22,22*8(t2)
> 	sdc1	$f23,23*8(t2)
> 	sdc1	$f24,24*8(t2)
> 	sdc1	$f25,25*8(t2)
> 	sdc1	$f26,26*8(t2)
> 	sdc1	$f27,27*8(t2)
> 	sdc1	$f28,28*8(t2)
> 	sdc1	$f29,29*8(t2)
> 	sdc1	$f30,30*8(t2)
> 	sdc1	$f31,31*8(t2)
>> Hello,
>> context?
>> singe double value.
>> regno * 8
>> (regno&  ~1) * 8    (i.e. calculate offset of closest
>> then:
>> On big endian:
>> On little endian:
>> Thanks,
>> Aleksandar
>> OSTech
Any comments?
Is there anywhere an overview of particular MIPS cpu-s that we support
and what kind of fpu-s they have?
Aleksandar
Ok, to conclude this:
it is treated the way it is because of the emulator.
I tried with implementing saving/restoring FP registers using swc1 or sdc1 depending on the FR bit in CP0 status
register and it seems to work (I don't have a 64-bit FPU target), but then there is a mismatch between representation on
 a target with real FPU vs target without FPU.
So, while it seems that on 32-bit FPUs we are executing 16 superfluous instructions per store/load of FP context, they
don't seem to hurt either.
With changed GDB's idea of how are FPRs stored, things work consistently, regardless of FPU presence.
Drawback is that GDB will only interpret FP registers as 32 single precision registers (paired to represent 16 double
precision registers) and can not really represent real 64-bit FPU.
