mq_notify seems only notify once
02/23/2010 7:31 AM
post47964
#define QUEUE_NAME "/testqueue"
mqd_t queue;
int PulseHandler (message_context_t *ctp, int code, unsigned flags, void *handle)
fprintf(stderr, "Plulse excuted ! \n");
static char message[256];
struct mq_attr attr;
// mqd_t queue = mq_open (QUEUE_NAME, O_RDONLY , S_IRUSR | S_IWUSR, NULL);
memset(message, 0 , 256);
memset(&attr, 0, sizeof(attr));
mq_getattr(queue,&attr);
mq_receive( queue, message, attr.mq_msgsize, NULL );
fprintf(stderr, "%s \n", message);
fprintf(stderr, "Plulse excuted finished! \n");
return 0;
dispatch_context_t *ctp;
attr.mq_maxmsg = 10;
attr.mq_msgsize = 255;
queue = mq_open (QUEUE_NAME, O_CREAT |O_EXCL | O_RDONLY , S_IRUSR | S_IWUSR, &attr);
struct sigevent event;
dispatch_t * dpp = dispatch_create();
/* Attach a handler function to a pulse code */
int TimerPulseCode = pulse_attach (dpp, MSG_FLAG_ALLOC_PULSE, 0, PulseHandler, NULL);
/* Create a connection to a channel that our resource manager is receiving on */
int SelfCoid = message_connect (dpp, MSG_FLAG_SIDE_CHANNEL);
/* This macro fills in the event structure */
SIGEV_PULSE_INIT(&event, SelfCoid, 24, TimerPulseCode, 0);
mq_notify( queue, &event );
/* allocate a context structure */
ctp = dispatch_context_alloc(dpp);
while(1) {
printf("sleep now 11111\n");
if ( NULL != (ctp = dispatch_block(ctp)) )
printf("sleep now \n");
dispatch_handler( ctp );
else
printf("errno \n");
return -1;
return EXIT_SUCCESS;
See the test code above, it is fine to notify when recive the first message, but after ward notify do not really work.
am i missing anything?
