Forum Topic - __cpu_membarrier implementation:
In trunk/lib/c/public/x86/cpuinline.h __cpu_membarrier defined as
# define __cpu_membarrier()												\
		/* check for X86_CPU_SSE2 */									\
		if (__cpu_flags & (1 << 15)) {									\
			__asm__ __volatile__ ("mfence");							\
		} else {														\
			__asm__ __volatile__ ("lock; orb $0,0(%esp)");				\
In trunk/lib/c/public/x86/smpxchg.h _smp_xchg defined as
static __inline int __attribute__((__unused__)) _smp_xchg(volatile unsigned *__dst, unsigned __src) {
	__asm__ __volatile__(
		"xchgl %0,%1"
		:"=r" (__src)
		:"m" (__atomic_fool_gcc(__dst)), "0" (__src)
		:"memory");
	return __src;
A question is: is not "memory" required in clobber list for __cpu_membarrier? As far as I understand that makes sure
compiler does not reuse values evaluated from memory across the assembler block.
Re: __cpu_membarrier implementation
Hi Oleh,
Funny you should mention it.  This was corrected recently on the trunk
(r249886) as part of PR 60043.  Thank you for the bug report though.
Neil
