09/14/2007 1:53 PM
post1218
1) what is RUNCPU and KERNCPU
x86 as example:
2 dual-core system with hyper-threading(pay attention to apic id)
Processor 0, Speed 2793 Mhz, CPUID: GenuineIntel
Genuine Intel® CPU 2.80GHz
Family 15, Model 4, Stepping 8
Feature flags 0000649D:BFEBFBFF
L1 cache: 28K Bytes, L2 cache: 2048K Bytes
Processor Initial APIC ID: 0
Processor 1, Speed 2793 Mhz, CPUID: GenuineIntel
Processor Initial APIC ID: 6
Processor 2, Speed 2793 Mhz, CPUID: GenuineIntel
Processor Initial APIC ID: 2
Processor 3, Speed 2793 Mhz, CPUID: GenuineIntel
Processor Initial APIC ID: 4
Processor 4, Speed 2793 Mhz, CPUID: GenuineIntel
Processor Initial APIC ID: 1
Processor 5, Speed 2793 Mhz, CPUID: GenuineIntel
Processor Initial APIC ID: 7
Processor 6, Speed 2793 Mhz, CPUID: GenuineIntel
Processor Initial APIC ID: 3
Processor 7, Speed 2793 Mhz, CPUID: GenuineIntel
Processor Initial APIC ID: 5
this one is related to kernel when you read kernel source or kernel crash which talking about [RUNCPU,KERNCPU] in kernel
crash. we all talk about smp so KERNCPU is cpu number we read from cpunum and cpunum is assigned when we switch into
kernel mode. RUNCPU is a function call to get current cpu number in tr(x86). actually both are read from tr but under
some conditions that KERNCPU is different from RUNCPU: cpu 1 enters kernel state(now) but cpu2 dumped when some
condition happened then it called crash(), now we are in different cpu KERNCPU and RUNCPU.
09/14/2007 2:03 PM
post1221
Is that ok to post code here?
09/14/2007 3:11 PM
post1231
It it doesnt violate someone's copyright, I dont see why not.
09/14/2007 3:10 PM
post1230
RUNCPU is the one you're currently running on. KERNCPU is the cpu that has entered the kernel.
If a 0 has taken an interrupt while cpu 2 is in the kernel
seen from cpu 0: RUNCPU==0, KERNCPU==2
seen from cpu 2: RUNCPU==2, KERNCPU==2
09/14/2007 3:19 PM
post1232
Thanks Attila, that is my conclusion please!
09/14/2007 3:29 PM
post1233
#if defined(WANT_SMP_MACROS) || defined(VARIANT_smp)
#define KERNCPU ((unsigned)cpunum)
#else
#define KERNCPU 0
#endif
#if defined(VARIANT_smp)
#ifndef PROCESSORS_MAX
#define PROCESSORS_MAX 8
#endif
#define NUM_PROCESSORS num_processors /*yzhao num_processors is assigned in syspage_init(), is from __syspage_ptr->
num_cpu*/
#define RUNCPU get_cpunum()
#define SPINLOCK(spin) do { while((spin)->value); } while(_smp_xchg(&(spin)->value, 1) != 0)
#define SPINUNLOCK(spin) ((spin)->value = 0)
#define SENDIPI(cpu,cmd) send_ipi(cpu,cmd)
#define SMP_FLUSH_TLB() if(num_processors > 1) smp_flush_tlb()
#define SMP_SPINVAR(class,var) class intrspin_t var
#define INTR_LOCK(s) InterruptLock(s)
#define INTR_UNLOCK(s) InterruptUnlock(s)
#else
#define PROCESSORS_MAX 1
#define NUM_PROCESSORS 1
#define RUNCPU 0
#define INTR_LOCK(s) InterruptDisable()
#define INTR_UNLOCK(s) InterruptEnable()
#endif
so under UP both of them are always 0 because it is representing cpu:)
/* yzhao we are still talking about RUNCPU
*get_cpunum is defined in ker/arch/smp/smp_get_cpunum.S, I will only give x86 example and other archs are similar.
.globl get_cpunum
get_cpunum:
GETCPU %ax, %eax
ret
/* yzhao so get_cpunum is only a function to call GETCPU with ax register as temporily register.*/
.macro GETCPU, reg1, reg2
// &seg
// mov lapicid_addr,®2 // LAPIC id register address
// mov (®2),®2 // Read the id
// shr $24,®2 // Id is in bits 27-24
xor ®2,®2 // clear reg1 and reg2
str ®1 // store the segment selector from Task register in reg1
shr $3,®2 // shift right 3
sub $32,®2 // -32 then we get it.
.endm
if(genflags & INTR_GENFLAG_LOAD_CPUNUM) {
if(NUM_PROCESSORS == 1) {
gen_load(REGNO_ESI, 0);
} else {
static uint8_t cpunum_burst[] = {
0x31, 0xf6, // xor %esi,%esi
0x0f, 0x00, 0xce, // str %si
0xc1, 0xee, 0x03, // shr $3,%esi
0x83, 0xee, 0x20, // sub $0x20,%esi
add_code(cpunum_burst, sizeof(cpunum_burst));
/* yzhao obviously cpu number is in task register because finally we got it from reg1 and contents of reg1 is from
task register. */
/* yzhao let's take a look at init_cpu() it will tell us more*/
void
init_cpu() {
static int cr0 = 0;
static paddr32_t cr3;
int cpu;
struct x86_seg_descriptor_entry *sdp;
X86_TSS *tssp;
uintptr_t addr;
// EM MP NE ET
// 1 0 1 0 No FPU
// 0 1 1 1 FPU == 387
// 0 1 1 x FPU > 387
// The BIOS will have correctly set up the various cache options for the
// boot processor only. Therefore we use it as a model for all other
// processors.
if(cr0 == 0) {
cr0 = rdcr0() & ~(X86_MSW_EM_BIT | X86_MSW_MP_BIT);
cr0 |= X86_MSW_TS_BIT | X86_MSW_NE_BIT | X86_MSW_AM_BIT;
if((__cpu_flags & CPU_FLAG_FPU) && !fpuemul) {
cr0 |= X86_MSW_MP_BIT;
} else {
cr0 |= X86_MSW_EM_BIT;
set_trap(0x100 | 0x07, __fpuemu_stub);
if(SYSPAGE_ENTRY(cpuinfo)->cpu == 386) {
cr0 |= X86_MSW_ET_BIT;
cr3 = rdpgdir();
ldcr0(cr0);
ldpgdir(cr3);
cpu = init_send_ipi();
#else
cpu = 0;
#endif
tssp = _scalloc(sizeof(struct x86_tss_entry));
tss[cpu] = tssp;
tssp->ss0 = ker_ss;
tssp->esp0 = 0; // Temp value till first thread runs
tssp->pdbr = (unsigned)rdpgdir();
addr = (unsigned) tssp;
sdp = &_syspage_ptr->un.x86.gdt[32+cpu]; /*yzhao? it seemed gdt already been filled in in bios.s*/
sdp->flags = X86_TYPE_TSS32_SEG | X86_DPL1;
sdp->base_lo = addr & 0xffff;
sdp->base_hi = (addr >> 16) &...
09/14/2007 4:15 PM
post1235
__ker_entry:
PUSHREG / Save all registers in thread register save area
GETCPU %bp, %ebp
mov SIZEOF_REG-(2*4)(%esp),%edx / Pointer to users stack frame
add $4,%edx / Step over return address, point at arguments
lea -REG_OFF(%esp),%ebx / Recover actives
mov SMPREF(ker_stack,%ebp,4),%esp // switch to the kernel stack
jmp __common_ker_entry
09/14/2007 4:17 PM
post1236
__common_ker_entry:
#ifdef VARIANT_instr
SAVE_PERFREGS 0
#endif
#ifdef VARIANT_smp
mov %eax,%esi // save kernel call number /*yzhao in userspace every kernel call save kernel call number in eax, see
ker_call_table*/
aquire_kernel_attempt:
sti
// Wait for need to run to clear if we're not on the right CPU.
1:
cmpl $0,need_to_run /*yzhao need_to_run thread == 0? */
jz 3f /*yzhao need_to_run==0, that means no thread need to run and preempt me, just go ahead, jump to 3 */
cmpl %ebp,need_to_run_cpu /*yzhao need_to_run!=0, compare current cpu == need_to_run_cpu? */
je 3f /*yzhao need_to_run_cpu is current cpu, jump to 3*/
pause /*yzhao pause, it was suggested by Intel for spin-loop wait, in Intel Xeon, P4 and dual cores
we have to */
jmp 1b
// See if anybody else is in the kernel
3:
mov inkernel,%eax
test $INKERNEL_NOW,%eax /*yzhao and immed32, eax, set SF,ZF,PF according to result*/
jnz 1b /*yzhao if (eax & INKERNAL_NOW) jmp 1b*/
cli /*yzhao disable irq*/
end_aquire_kernel_attempt:
mov %eax,%edi /*yzhao mov inkernel to edi */
andl $0x00ffffff,%edi /*yzhao get edi lower 24 bits*/
mov %ebp,%ecx
shl $24,%ecx /*yzhao get cpunum, ebp lower 8 bits represent cpunum */
orl %edi,%ecx / Set cpunum
orl $INKERNEL_NOW,%ecx /*yzhao cpunum|inkernel|INKERNEL_NOW*/
lock; cmpxchg %ecx,inkernel /*yzhao lock bus and xchg ecx and inkernel*/
jnz aquire_kernel_attempt /*yzhao if ecx is not same with inkernel, again */
// We are the kernel
mov %esi,%eax // restore kernel call number
#else
LOCKOP
orl $INKERNEL_NOW,inkernel / In the kernel (restartable)
#endif
sti /*yzhao enable irq*/
cld
mov %eax,SYSCALL(%ebx)
mov TFLAGS(%ebx),%ecx
and $~(_NTO_TF_KERERR_SET+_NTO_TF_BUFF_MSG+_NTO_TF_KERERR_LOCK),%ecx
mov %ecx,TFLAGS(%ebx)
cmp $__KER_BAD,%eax
jae bad_func
push %edx
push %ebx
#if defined(VARIANT_instr)
call *_trace_call_table(,%eax,4)
#else
call *ker_call_table(,%eax,4)
#endif
/ assuming that none of the kernel routines modify the 'act' parm
/ on the stack
pop %ebx
test %eax,%eax
jge set_err
09/14/2007 4:19 PM
post1238
conclusion:
KERNCPU kernel on which cpu.
RUNCPU which cpu current code running on.
09/14/2007 4:28 PM
post1240
Yao Zhao wrote:
> conclusion:
Yup. That's my understanding too.
09/18/2007 11:35 AM
post1353
Because of code here then you know only one cpu can enter kernel state or get INKERNEL_NOW for system call. This makes
KERN_CPU sense. It means there is a big kernel lock and kernel is not quite smp capable although interrupt, exceptions
may not need this.
Current kernel code relies this too much, I guess it is not easy to make it more smp capable but it is possible. Need a
project?
it will be released in __ker_exit.
1:
we have to */
jmp 1b
3:
mov inkernel,%eax
mov %ebp,%ecx
09/18/2007 11:42 AM
post1356
> From: Yao Zhao [mailto:yzhao@qnx.com]
> Sent: September 18, 2007 11:36 AM
> To: ostech-core_os
> Subject: Re: kernel reading notes
> exceptions may not need this.
> easy to make it more smp capable but it is possible. Need a project?
[ Code comments snipped ]
Yao,
I'm not sure what your intention is with these posts?
* Are you trying to fix a particular problem; if so then can you
create a post with a more accurate synopsis/title.
* Are you simply relaying your own personal notes from having read
through the sources; if so, then perhaps contributing the commentary
to an appropriate wiki page would be better
* Are you doing something else?
This forum thread seems to be kind of random, and with your statement
above, I'm not sure where you are headed.
Thomas
Re: RE: kernel reading notes
09/18/2007 1:37 PM
post1358
how to edit my past posts?
09/18/2007 1:48 PM
post1360
can any member in myqnx create wiki in myqnx?
09/18/2007 5:52 PM
post1373
If have joined the OS project, yes.
The wiki tells me that you have not joined the project. So you cant edit
wiki pages yet.
There should be a "join" button on the OS project page:
http://community.qnx.com/sf/projects/core_os
Once you've joined and logged in though myqnx, you should be able to
edit the new new "Kernel Reading Notes" page that i've created:
<http://community.qnx.com/sf/wiki/do/viewPage/projects.core_os/wiki/KernelReadingNotes?_message=1190152282694>
I've created that page as an empty template as a suggestion as to how we could capture code commeents.
To start, you might want to try adding some of your stuff under the x86/kernel.s heading.
-ad
09/19/2007 12:02 PM
post1401
testing if replying by email to a posting here causes bounced-email reports.
RE: RE: kernel reading notes
09/18/2007 2:07 PM
post1361
> Sent: September 18, 2007 1:38 PM
> To: ostech-core_os
> Subject: Re: RE: kernel reading notes
You can't. You can delete and re-post but you
can't edit the messages themselves.
Thomas
Re: RE: RE: kernel reading notes
09/18/2007 4:43 PM
post1369
Sorry! I didn't find a "delete" button either.
I will delete them and post to a wiki page.
09/18/2007 11:47 AM
post1357
> or get INKERNEL_NOW for system call. This makes KERN_CPU sense. It
> although interrupt, exceptions may not need this.
This is by design. The amount of time spent in a microkernel kernel
call is typically so short as to not be an issue. Interrupts
acquire the kernel lock after the EOI, in order to process any event
deliveries/scheduling decisions that were caused during interrupt
processing.
> 1:
> jz 3f /*yzhao
> je 3f
> dual cores
> we have to */
> jmp 1b
> 3:
> mov inkernel,%eax
> jnz 1b /*yzhao if
> cli /*yzhao
> disable irq*/
> to edi */
> 24 bits*/
> mov %ebp,%ecx
> and inkernel*/
> http://community.qnx.com/sf/go/post1353
cburgess@qnx.com
09/18/2007 1:46 PM
post1359
09/18/2007 11:38 AM
post1354
UP code flow(boot)
hardware/startup/lib/_main.c
_main
startnext
cpu_startnext
exec386
services/system/ker/x86/_cstart_.S _start
services/system/ker/_main.c: _main
kernel_main
init_objects
idle
09/18/2007 11:41 AM
post1355
smp code flow(boot)
other cpus boot up procedure:
smp_start
cpu_startnext
smp_spin_vaddr (in init_smp we initialized smp_spin_vaddr = smp_spin)
smp_spin ( hardware/startup/lib/x86/callout_apstart.S)
_smpstart
init_smp
ker_start
in a nutshell, the first cpu goes into normal boot(see UP) and calls smp_hook_rtn(start_aps), in start_aps it will loop
to run board_smp_start(i, smp_start), in x86 board_smp_start is just apic_smp_start then first call of board_smp_start
will copy apstart16_end - apstart16_start code to a block of low address memory and also set apstart32_ptr with
smp_start. write INIT, STARTUP to Apic then this cpu will start from smp_start (actually from apstart16_start then it
will jump to 32 bit protection mode). in smp_spin it will finally jump to struct x86_smpinfo_entry.ap_start_addr and it
is _smpstart.
hardware/startup/lib/x86/cstart32.S
_start
_main
hardware/startup/boards/bios/main.c
main smp_hook_rtn startnext
hardware/startup/lib/init_smp.c
init_smp(
smp_hook_rtn = start_aps;
/* yzhao this will be called in startup/lib/_main.c _main */
smp_spin_vaddr = (void (*)(void))&smp_spin;
//Hook into the sizing/writing list
smp_prev_output_rtn = callout_output_rtn;
callout_output_rtn =
(output_callout_t *)callout_output_smp;
