Forum Topic - posix_spawnp() not working with relative paths:
Hi guys,
working with posix_sawnp() showed one very inconvenient behaviour compored to the classic spawnp() variant.
I am focusing on the ...p() variant, which checks for scripts and also PATH environment.
Documentation of posix_spawnp() says this about the given file to be spwaned:
<snip>
   If the file parameter _contains_ a slash character, the file parameter is used as the pathname for the new process
image file.
</snip>
it says "contains" and excatly this is not working.
The Implementation only checks for starting with '/'  -> check lib/c/1d/posix_spawnp.c
So you can't use posix_spawnp() calls with relative file paths, so a ./MyBinary is not working.
I think the implementation of this ...p() variant should be changed in a way that it behaves the same way the none POSIX
 spwanp() does for relative file paths.
any suggestions?
TIA
/hp
Re: posix_spawnp() not working with relative paths
no comments on this?
I guess I have to file a ticket -> PR
Actually the current implementation (r217700) looks - based on a quick
glance - correct to me.  It does check for a leading path separator at
line 57, but only to shortcut directly through to posix_spawn() in the
absolute path case.  I suspect that something else is not quite right.
Does your application work if you explicitly include "./" on the PATH?
Neil
> Regards,
> Neil
If you want to add CWD to your Path you have to add "." to your PATH.
I don't know anybody how has a "./" in PATH.
Elements in PATH are directories that do not to have a trailing "/".
The incorrectness is in the difference of documentation and implementation.
It says: "if the given filepath *CONTAINS* ..."
this not checked, just compare the part of filepath resolution to spawnp(), it is different and in my eyes incomplete.
And ... just try to launch a binary with "./binary"
It will not work with posix_spawnp() and that's an error
even if I do not have CWD in my PATH addressing the binary with ./binary has to work.
/hp
> > Regards,
> > Neil
Yes, that's why I was asking.  Does adding "./" to your PATH workaround
the problem for you for now?  I'm writing a PR for this but it would be
useful to know if that works around the problem.
Neil
I've gone ahead and raised PR 72089 for this.  If you raise a support ticket, please let your support rep know the PR
number.
Neil
AW: posix_spawnp() not working with relative paths
I don't have the chance to test that, sorry.
/hp
>Von: Neil Schellenberger [mailto:community-noreply@qnx.com]
>Gesendet: Montag, 19. Oktober 2009 20:34
>An: ostech-core_os
>Betreff: Re: posix_spawnp() not working with relative paths
>> > quick glance - correct to me.  It does check for a leading path
>> > separator at line 57, but only to shortcut directly through to
>> > posix_spawn() in the absolute path case.  I suspect that
>on the PATH?
>> > Regards,
>> > Neil
>implementation.
>even if I do
>has to work.
>workaround the problem for you for now?  I'm writing a PR for
>this but it would be useful to know if that works around the problem.
>Regards,
>Neil
>OSTech
>http://community.qnx.com/sf/go/post40261
