Forum Topic - pidin map on 6.4.x:
pidin map on 6.4.x
"pidin map" will only show a single "Mapped Phys Memory".  This occurs  on x86 and PPC (600).  I have a number of
drivers that map multiple regions - usually a control region and a data region but only a single region is reported.
 A nand file system with control registers at 0xe0005000 (4Kb) and data at 0x10000000 (256Mb).  But with 6.4.0/1 only
one region is shown
6.4.0 and 6.4.1
# pidin -Pfs-yaffs map
     pid tid name               prio STATE            code  data        stack
  131095   1 sbin/fs-yaffs       10r RECEIVE          272K  652K  8192(516K)*
             Mapped Phys Memory @80100000 (e0005000)        256M  S
# pidin -Pfs-yaffs me
            /dev/mem           @80100000 (       0)        256M
6.3.2
    8203   1 proc/boot/fs-yaffs  10r RECEIVE          260K  656K  8192(516K)*
            mem                @80100000             4096  4096
            mem                @80102000             256M
btw just tried the latest sin and it has the same problem.  a single mem region only
RE: pidin map on 6.4.x
This looks like a known issue PR66114, but it is unclear if this will be
fixed in 6.4.1.
Chris
From: Warren Deitch [mailto:community-noreply@qnx.com]
Sent: Monday, April 13, 2009 4:25 AM
To: osmeta-core_os
Subject: pidin map on 6.4.x
on x86 and PPC (600).  I have a number of drivers that map multiple
region is reported.
at 0x10000000 (256Mb).  But with 6.4.0/1 only one region is shown
6.4.0 and 6.4.1
stack
8192(516K)*
stack
8192(516K)*
6.3.2
stack
8192(516K)*
            mem                @80102000             256M
region only
OSMeta
http://community.qnx.com/sf/go/post26734
Re: pidin map on 6.4.x
Aleksander posted a diff for CI here - http://community.qnx.com/sf/go/post25371 - it just needs someone to review
it.
Colin
> fixed in 6.4.1.
> Chris
> To: osmeta-core_os
> region is reported.
> 6.4.0 and 6.4.1
> stack
> 8192(516K)*
> stack
> 8192(516K)*
> 6.3.2
> stack
> 8192(516K)*
>             mem                @80102000             256M
> region only
> OSMeta
> OSMeta
> http://community.qnx.com/sf/go/post26743
cburgess@qnx.com
Thank you Colin,
   The patch works for me on PPC.  Both pidin map and pidin me show all the physical memory details now.   I have not
tried it on x86 yet.
Sorry to say the patch has introduced other bugs.  pidin arg and pidin env no longer work.  Tried on 6.4.1 and 6.4.0.
They both fault with 'couldn't read stack: Server fault on msg pass'
pidin arg displays only the pid then faults.
pidin env displays the pid and name then faults.
All the other pidin xxx worked ok.
Warren, thank you for your feedback.
The errors you saw were on a  ppc target, right? I was
testing on x86 and all worked.
Aleksandar
>> env no longer work.  Tried on 6.4.1 and 6.4.0. They both fault with
> The errors you saw were on a  ppc target, right? I was testing on x86
> and all worked.
  And now I tried on a ppc target, it worked for me.
Does it crash for you for *any* process, or some process in
particular? I would like to reproduce it here.
Aleksandar
"pidin arg"  and  "pidin -Pio-hid arg" both fail.    MPC 8349 (procnto-600-instr - last update svn ver 218052)
# pidin arg
     pid Arguments
       1 proc/boot/procnto-600-instr
couldn't read arg: Server fault on msg pass
       2
       3
       4
   16389
   16390
   20487
More instances snipped
  315423
  327712
  364570
  909323
# pidin -pio-hid arg
     pid Arguments
  155668
# pidin env
     pid name               Environment
       1 /procnto-600-instr
       2 proc/boot/slogger
       3 proc/boot/io-usb
       4 oc/boot/devb-umass
   16389 sbin/tinit
   16390 sbin/pipe
   20487 sbin/mqueue
   40969 usr/sbin/inetd
snip
  315423 hoton/bin/devi-hid
  327712 usr/photon/bin/pwm
  364570 bin/sh
  925707 bin/pidin
# pidin -pio-hid env
  155668 sbin/io-hid
I just committed a fix to services/system for this - it's nothing to do with pidin :-)
Sent: Wed 4/15/2009 8:13 PM
To: osmeta-core_os
Subject: Re: pidin map on 6.4.x
# pidin arg
     pid Arguments
       2
       3
       4
   16389
   16390
   20487
  315423
  327712
  364570
  909323
     pid Arguments
  155668
# pidin env
       2 proc/boot/slogger
       3 proc/boot/io-usb
   16389 sbin/tinit
   16390 sbin/pipe
   20487 sbin/mqueue
snip
  364570 bin/sh
  925707 bin/pidin
  155668 sbin/io-hid
OSMeta
http://community.qnx.com/sf/go/post27160
Attachment: Text winmail.dat 5.02 KB
> with pidin :-)
I was really confused since the message printed comes from
code I haven't touched. Thanks Colin!
And thanks Warren for your feedback.
Aleksandar
Tried it all again with the latest coreos update and the problem has gone.   All pidin xxx commands worked under procnto
-600-instr (updated today) .  Thanks to all of you!!!   :-)
I have a minor gripe with pidin irq - the columns do not line up if the irq reference or value  exceeds 9.   Given the
amount of whitespace in front of the numbers, they could - pidin fds does.
  131089   2 sbin/devf-generic
  131090   1 sbin/io-pkt-v4-hc
  131090   2 sbin/io-pkt-v4-hc
                6       0x80000000    0 T-- @0x480bd960:0x4813fafc
                7              0xb    0 T-- @0xfe385604:0x48172040
                8             0x21    0 T-- @0xfe391bbc:0x48180740
                9             0x22    0 T-- @0xfe391b74:0x48180740
                10             0x24    0 T-- @0xfe391bbc:0x4817eac0
                11             0x25    0 T-- @0xfe391b74:0x4817eac0
  131090   3 sbin/io-pkt-v4-hc
  131090   4 sbin/io-pkt-v4-hc
  131090   5 sbin/io-pkt-v4-hc
  131094   1 sbin/io-display
  131094   2 sbin/io-display
Picky, picky! :-)
procnto-600-instr (updated today) .  Thanks to all of you!!!   :-)
> OSMeta
> http://community.qnx.com/sf/go/post27224
cburgess@qnx.com
Not related to the question posted. But by the way is fs-yaffs supported under 6.4.x ? Is the source under SVN?
Ashwin
fs-yaffs is not a QNX binary - it must be Warren's.
> Thanks,
> Ashwin
> OSMeta
> http://community.qnx.com/sf/go/post33373
cburgess@qnx.com
The people who provided the hardware also provided Rob Krten's yaffs package (from Parse Software Devices).   It has
serious problems executing scripts from the filesystem but I have not recently looked for a QNX nand filesystem that
supports the Micron MT29F2G08.
That is still on my todo list.
