Forum Topic - QNX asynchronous message passing library:
hi,
     Is asynchronous message passing library available for QNX ?..
     If it is not available what is the best way to simulate it across
     machines ?
-RAJ
RE: QNX asynchronous message passing library
The library is libasyncmsg.{a,so}, and it's included in Neutrino 6.3.0
and later. Asynchronous messaging is considered to be an experimental
feature, so use it at your own risk (see your license agreement for
details). You can't use it across Qnet, and it doesn't work correctly on
multiprocessor systems. Here's a link to the technote on it:
http://www.qnx.com/developers/docs/6.4.0/neutrino/technotes/async_messag
ing.html
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
Shouldn`t mq be flagged with the same warnings?
That being said I was under the impression with 6.3.2 it was taken out of experimental status.
> From: Steve Reid [mailto:community-noreply@qnx.com]
> Sent: December-18-08 10:23 AM
> To: osmeta-core_os
> Subject: RE: QNX asynchronous message passing library
> on
> g
> ing.html
> Technical Editor
> OSMeta
> http://community.qnx.com/sf/go/post18937
Yes, the same warnings apply to mq.
Technical Editor
> Sent: December-18-08 11:00 AM
> To: osmeta-core_os
But I don`t see it in the documentation.
> Technical Editor
> OSMeta
> http://community.qnx.com/sf/go/post18953
