Forum Topic - Scheduling processes-threads and questions...: (6 Items)
Hi everybody,
*) I would like to create a number of processes(single threaded) and run them on a Neutrino x86 system using the FIFO
scheduling, and measure the execution time of each process.
 I know that threads on Neutrino are scheduled globaly across all processes. I have study some of the documentetion
about scheduling-algorithms at http://www.qnx.com/developers/docs/6.4.0/neutrino/sys_arch/kernel.html#SCHEDULING. I know
 that the FIFO or RR algorithm is only applied when 2 or more threads share the same priority and are in the READY state
1) Can i implement the * creating a number of programs (single-threaded) set the highest-priority to each thread-process
program and set scheduling-algorithm as FIFO ? Will this approach give me correct(with the mean of real) results for the
 processes execution time ?
2) The other solution i thought is to create a new image of Neutrino where i haved enabled only the FIFO scheduling-
algorithm.Altering some files as nano_sched.c, ker_sched.c in the services/system/ker/ directory perhaps i can enable
only the FIFO algorithm for all threads and processes. Then built all the source and create a new image. After booting
the new image i can develope some processes and measure the execution times.
I imagine that the second approach is more difficult than the first, but i think it will give better results. What is
your advice ? .
I have checked also the topic: http://community.qnx.com/sf/
discussion/do/listPosts/projects.core_os/discussion.newcode.topc1888
thanks in advance
Re: Scheduling processes-threads and questions...
Is FIFO scheduling your objective, or your proposed method of getting execution times? If all you want is exections
times, the most accurate way to do that is with an instrumented kernel and use the "System Profiler" view of Momementics
to analyse it after the fact.
Interesting. Let us know if that boots. FIFO scheduling is inherently dangerous. One tiny infinite-loop anywhere and the
whole system will hang.
-ad
Yes FIFO scheduling is my objective but execution times also. So will the first approach give me any real results ?
What exactly i want to do is to remove any scheduling policy neutrino supports (RR-Sporadic) and enable only the FIFO
non-preemptive policy for all processes/threads. Then create a new image of qnx-neutrino and start some processes on the
 new image. Could you give me any hint to achieve this ? The scheduler files : nano_sched.c, ker_sched.c, nano_clock.c,
kexterns.c are complicated and i think there is not a lot of documentation for this(not very well commented code at
least for my level). If this attempt fails i will try the (1) i wrote on my first post, but i don't  think that i will
take objective results.
thanks Atila
RE: Scheduling processes-threads and questions...
I'm not sure any threads set their policy explicitly - it's all inherited (there may be exceptions).
You can just launch all processes in the boot image with fifo policy.
add [prio=10f]
From: Andreas Polychronopoulos [mailto:community-noreply@qnx.com]
Sent: Fri 12/12/2008 6:38 PM
To: osmeta-core_os
Subject: Re: Scheduling processes-threads and questions...
thanks Atila
OSMeta
http://community.qnx.com/sf/go/post18566
Attachment: Text winmail.dat 4.14 KB
Re: RE: Scheduling processes-threads and questions...
In the documentation i read that there are some kernel calls (pthread_setschedparam()) which the threads can use to
change the scheduling-policy and their priority.
> add [prio=10f]
So i did as you said but when i run pidin after booting  there are a lot of processes with RR policy and FIFO also. I
attach my build file with which i create the image (mkifs). I would appreciate if you chek out my build file. I create
it from the Momentics 6.4.0 and just change the line [prio=10o] to [prio=10f].
thanks a lot
Attachment: Text test_qnxbase.mkifs 1.49 KB
Yes, it looks like some threads do set their prio parameters, of course.
>> add [prio=10f]
> thanks a lot
> OSMeta
> http://community.qnx.com/sf/go/post18579
cburgess@qnx.com
