Forum Topic - Databases on QNX6.4:
Databases on QNX6.4
We need implement a database system in QNX6.4, but we don't sure about what engine to use. Someone have an idea to wich
database to use, such as sybase, MySql..etc
Re: Databases on QNX6.4
The databases which work in 6.2 or 6.3 should work in 6.4.
The choice of the base depends first of all on what you needs. Large or the small base. Given on the disc or in the RAM
memory.
Look:
Raima Database Manager (RDM) Embedded => http://www.raima.com/products/rdm-embedded/specification/
McObject’s embedded database - eXtremeDB  => http://www.mcobject.com/embedded_database_products
MySQL 5.0  - http://dev.mysql.com/get/Downloads/MySQL-5.0/mysql-5.0.67-nto-qnx6.2.1-i386.tar.gz  - I try it in 6.4 work
very well.
Empress RDBMS  => http://www2.empress.com/qnx/empqnx.html
Oracle Berkeley DB  => http://www.oracle.com/technology/products/berkeley-db/db/index.html  very good work on 6.4
DB2® Everyplace® Enterprise Edition => http://publib.boulder.ibm.com/infocenter/db2e/v9r1/index.jsp?topic=/com.ibm.
db2e.doc/dbeint0316.html
SQLite => http://www.sqlite.org/  work on QNX 6.3/6.4
For your answer, we are using MySQL in all of our applications and we are very happy with it.
Do you know if MySQL is making the binaries for the QNX newer versions?
On Fri, Sep 11, 2009 at 01:50:23PM -0400, mariana viale wrote:
> Thanks
You can get it here:
ftp://ftp.netbsd.org/pub/pkgsrc/packages/QNX/i386/6.4.1_head_20090724/All
Check out the pkgsrc project:
http://community.qnx.com/sf/projects/pkgsrc
