Forum Topic - sprintf stops working after the German umlauts ä and ö, whereas ü does work: (7 Items)
Some of the German umlauts are breaking the snprintf (and sprintf) processing.
Here is the affected code:
#include <cstring>
#include <iostream>
using namespace std;
int main(int argc, char *argv[])
    char strTmp[75];
    cout << "cout directly - " << "Umlauts: üäöÄÖÜ" << " - strlen: " << strlen("Umlauts: üäöÄÖÜ") << endl;
    strncpy(strTmp,  "Umlauts: üäöÄÖÜ", sizeof(strTmp)); // works
    cout << "strncpy       - " << strTmp << " - strlen: " << strlen(strTmp) << endl;
    snprintf(strTmp, sizeof(strTmp), "Umlauts: üäöÄÖÜ");
    cout << "snprintf      - " << strTmp << " - strlen: " << strlen(strTmp) << endl; // shows only the first of the
umlauts (ue)
    sprintf(strTmp, "Umlauts: üäöÄÖÜ");
    cout << "sprintf       - " << strTmp << " - strlen: " << strlen(strTmp) << endl; // shows only the first of the
umlauts (ue)
Each line should show all of the six German umlauts, but this is the result:
$ ./test
cout directly - Umlauts: üäöÄÖÜ - strlen: 15
strncpy       - Umlauts: üäöÄÖÜ - strlen: 15
snprintf      - Umlauts: ü - strlen: 10
sprintf       - Umlauts: ü - strlen: 10
The Momentics workspace is using the Windows cp1252 code page. Momentics is 6.3.0 SP3 on Windows XP SP2. gcc 3.3.5 is
used:
C:/programme/QNX630/host/win32/x86/usr/bin/qcc -V3.3.5,gcc_ntox86 -c -Wc,-Wall -Wc,-Wno-parentheses  -O -Y_cpp -fmessage
-length=0 -lang-c++         main.cpp
C:/programme/QNX630/host/win32/x86/usr/bin/qcc -V3.3.5,gcc_ntox86  -lang-c++ -lang-c++ -Y_cpp    -otest    main.o  -L. -
LC:/programme/QNX630/target/qnx6/x86/lib/gcc/3.3.5 -LC:/programme/QNX630/target/qnx6/x86/lib -LC:/programme/QNX630/
target/qnx6/x86/usr/lib
Why is the string truncated after the German ü (ue)?
TiA
Christian
Re: sprintf stops working after the German umlautsä and ö, whereasü does work
> processing.
> #include <cstring>
> #include <iostream>
>     char strTmp[75];
> strlen(strTmp) << endl; // shows only the first of the umlauts (ue)
Can you send a binary file of the program?
Just want to avoid any issue with unicode (when I cut and paste your
e-mail, I end up with the umlauts are in their unicode form).
Also, you could do:
{char *p=strTmp; (while(*p) { printf(" 0x%02x:%c",(unsigned)(*p), *p); p++;}
Just so we know exactlay what every function, or iostream is getting.
AW: sprintf stops working after the German umlautsä and ö, whereasü does work
I've seen problems with non-7-bit characters occuring
when the locale wasn't set correctly.
It's getting a little late over here, so I may be mistaken,
but I think calling
  setlocale( "C-TRADITIONAL" );
did help me in such cases.
- Thomas
> -----Ursprüngliche Nachricht-----
> Von: Stephane Boucher
> Gesendet: 17 April 2008 17:03
> An: osmeta-core_os
> Betreff: Re: sprintf stops working after the German umlautsä and ö,
> whereasü does work
> > processing.
> > #include <cstring>
> > #include <iostream>
> >     char strTmp[75];
> Also, you could do:
> OSMeta
> http://community.qnx.com/sf/go/post6985
Re: AW: sprintf stops working after the German umlautsä and ö, whereasü does work
I just tried the test case on a 6.4.0 system and they all printed out.
My first thought was the locale though...
> but I think calling
> - Thomas
>  > An: osmeta-core_os
>  > whereasü does work
>  > > processing.
>  > > #include <cstring>
>  > > #include <iostream>
>  > >     char strTmp[75];
>  > Also, you could do:
>  > _______________________________________________
>  > OSMeta
> OSMeta
> http://community.qnx.com/sf/go/post6987
cburgess@qnx.com
Re: AW: sprintf stops working after the Germanumlautsä and ö, whereasü does work
> out.
Well, me too, but I got a strlen of 21.  The textual lenght is 15, but
strlen() of the unicode version is 21 :-) (hence my cut and paste gave
me unicode strings)
Re: AW: sprintf stops working after the German umlauts ä and ö, whereas ü does work
That are good news.
The fix to set the locale before using snprintf leads to another problem when using Photon 8-(
When sending the above string, it is required to convert the characters to the utf-8 encoding Photon uses. This will
fail (string is truncated) when locale is set to C-TRADITIONAL.
The PxTranslateStateToUTF does work again, when I switch the locale back to "C".
My solution for this problem will be to drop snprintf and use stringstream instead. Therefore there is no need to set
the locale for me.
> but I think calling
> - Thomas
> > An: osmeta-core_os
> > whereasü does work
> > > processing.
> > > #include <cstring>
> > > #include <iostream>
> > >     char strTmp[75];
> )); // works
> Umlauts: üäöÄÖÜ");
> > Also, you could do:
the while/printf leads to:
 0x55:U 0x6d:m 0x6c:l 0x61:a 0x75:u 0x74:t 0x73:s 0x3a:: 0x20:  0xfffffffc:ü
After setting
(void)setlocale(LC_CTYPE, "C-TRADITIONAL");
Everything work as expected:
snprintf      - Umlauts: üäöÄÖÜ - strlen: 15
sprintf       - Umlauts: üäöÄÖÜ - strlen: 15
 0x55:U 0x6d:m 0x6c:l 0x61:a 0x75:u 0x74:t 0x73:s 0x3a:: 0x20:  0xfffffffc:ü 0xffffffe4:ä 0xfffffff6:ö 0xffffffc4:Ä
0xffffffd6:Ö 0xffffffdc:Ü
Thanks a lot for the quick and very helpful answers!
Christian
