Forum Topic - Could not find library libperl.so:
Hi everyone,
I experienced a problem while installing perl 5.
My target system is qnx 6.3.2, in which ssh is not installed by default. So I need to install openssh manually to
transfer files between the target machine and the host machine( run on fedora 10). And openssl and perl 5 are required
by the openssh installation. I tried to download and install under the instructions on the following website, but failed
http://community.qnx.com/sf/frs/do/viewRelease/projects.pkgsrc/frs.qnx_binary_packages_for_pkgsrc_2.head?_pagenum=4
The perl version I downloaded is perl-5.8.8nb4.tgz. I unzipped the file to /usr, add /usr/perl/bin to PATH and /usr/perl
/lib to LD_LIBRARY_PATH, log out and log in.
Then I tried to install openssl, which needed perl 5. But there was error information shown as:
"Could not find library libperl.so"
I checked the /usr/perl/lib and didn't find libperl.so either.
Could you tell me how to figure this out?
Thank you.
Yuan
Re: Could not find library libperl.so
On Thu, Jul 29, 2010 at 10:52:02PM -0400, Yuan Sun wrote:
> Hi everyone,
perl/lib to LD_LIBRARY_PATH, log out and log in.
> Thank you.
On my system:
# objdump -x /usr/pkg/bin/perl | grep NEEDED
  NEEDED               libperl.so
  NEEDED               libm.so.2
  NEEDED               libc.so.3
  NEEDED               libsocket.so.3
# readelf -d /usr/pkg/bin/perl | grep RPATH
 0x0000000f (RPATH)                      Library rpath: [/usr/pkg/lib:/usr/pkg/lib/perl5/5.10.0/x86pc-nto/CORE]
# ls -l /usr/pkg/lib/perl5/5.10.0/x86pc-nto/CORE/libperl.so
-r-xr-xr-x  1 root      root        1325778 Jun 02 15:44
rpath overrides LD_LIBRARY_PATH.  The root of your problem
is probably that you should use 'pkg_add' rather than 'tar'
to add packages so they're installed in the same prefix as
they were built (usually /usr/pkg).
Or you can usr 6.4.1+ which ships with ssh and friends.
Sean,
Thank you. I switched to 6.3.2 from 6.4.0 due to some other requirement of
the system. When I added the rpath to the LD_LIBRARY_PATH, it worked.
BTW, I cannot find pkg_add command on the target machine. Should I add any
path or install it manually if I want to use it later on?
Yuan
On Fri, Jul 30, 2010 at 11:56:25AM -0400, Yuan Sun wrote:
> Sean,
I think this os the 6.3.2 one:
http://community.qnx.com/sf/frs/do/listReleases/projects.pkgsrc/frs.qnx_bootstrap_binary_kit
