Forum Topic - Unable to access /dev/hd0t179:
Hi there:
We are banging our heads a bit here with this problem. We are trying to install Neutriono on a x86.
When we boot from CD, everything is fine. Internet connection and everything is perfectly fine.
Now, we want to install Neutrino on the hard drive, everything works fine until we get the message that says:
"Mounting Filesystems ...
Unable to access /dev/hd0t179"
Note that if we boot a partition editor, the installer has
created a type 179 partition.
We did quite a bit of research, and learned we needed to make modifications to our partition, which we did. But then we
still have this nagging problem.
Could someone point us in the right direction?
Re: Unable to access /dev/hd0t179
What is your QNX version ? Because I run some tests with QNX 6.5 M9 and tried to install it on a second partition of my
disk and I get exactly the same error.
Then I also expect a solution for that problem.
Christophe
Hi Christophe:
We are attempting to install the latest version (6.4.1).
Steve
On 2010-04-27 03:20, Christophe Hannoyer wrote:
> Hello,
my disk and I get exactly the same error.
> Christophe
> OSMeta
> http://community.qnx.com/sf/go/post52852
