Forum Topic - svn co fails: (14 Items)
svn co fails
This worked last time I tried it (in 2008).  But now all I get is:
svn checkout --username xxx http://community.qnx.com/svn/repos/coreos_pub
Authentication realm: <http://community.qnx.com:80>; Authorization Realm
Password for 'xxx':
Username:
Password for '':
Username:
Password for '':
svn: OPTIONS of 'http://community.qnx.com/svn/repos/coreos_pub': authorization failed: Could not authenticate to server:
 rejected Basic challenge (http://community.qnx.com)
Is this a known issue / is there a workaround?
Re: svn co fails
It now works.  Seems to have been a temporary issue.
Re: svn co fails
It appears to be failing again...
svn checkout --username user@foo.com http://community.qnx.com/svn/repos/core_networking/trunk
Password for 'user@foo.com':
Username: user@foo.com
svn: PROPFIND of '/svn/repos/core_networking/trunk': authorization failed (http://community.qnx.com)
Is this one of those "Wait a while and hope that it self corrects" issues?
Re: svn co fails
Depending on your licencing, you may be running afoul of changes to the
source access policy:
http://community.qnx.com/sf/wiki/do/viewPage/projects.community/wiki/UpdatedQNXSourceAccessPolicyFAQ
Neil
Re: svn co fails
this answer is a jocke ?
Is the core-network part of the OS microkernel ??
I got the impression that the days of "open source" are gone !!
Just some kind of  "RIMification" .... ?
--Armin
The
> Regards,
> Neil
> OSMeta
> http://community.qnx.com/sf/go/post54424
Re: svn co fails
The svn still fails, so I _assume_ that the core_networking source code is restricted, but I have not yet been able to
determine that.
A bit of the back story...
As a development partner, we downloaded, installed, and activated QNX 6.4.1.  It      appeared to us that some of the
code did not install ( specifically /dev/io-pkt ) and we're trying to remedy that.
A few things that we're trying to determine...
1. on a basic, fresh install of QNX 6.4.1, should the /dev/io-pkt directory and files be installed?
2. if not, is there a switch or checkbox that we should have used during the install?
3. can this code be added to the OS from the install CD, post-install?
4. if not, what is the proper way to obtain the missing directories/files?
5. is the /dev/io-pkt part of the core_networking source code (I think that it is)?
6. is the core_networking source code part of the restricted content?
Thank you,
Mark
Re: svn co fails
 determine that.
The io-pkt binaries ship (/sbin/io-pkt*) but no source.  There's no
/dev/io-pkt directory.  You can do a 'pidin' to see if it's running.
If it is an 'ifconfig' should show interfaces.
Re: svn co fails
> Thank you,
> Mark
Hello Mark,
The core_networking source code is part of the restricted content. That doesn't mean that you're not eligible to access
it though. As mentioned in the policy FAQ (http://community.qnx.com/sf/wiki/do/viewPage/projects.community/wiki/
UpdatedQNXSourceAccessPolicyFAQ), QNX Software Systems will continue to make its proprietary OS and middleware source
code available to qualified customers, partners, and educational institutions. However, some of this code will no longer
 be available to hobbyists or to the general public.
Download the QNX Restricted Content Application Form (http://www.qnx.com/download/feature.html?programid=20745) from the
 QNX download center. Print the form, fill it in, and email a scanned version to licensing@qnx.com. QNX Software Systems
 will evaluate your request and provide further instructions.
Mike Lemke
Engineering Operations
Re: svn co fails
>> Thank you,
>> Mark
> Hello Mark,
IMHO ... that's problematic because of the fact that this code contains
GPL 2.0  code (e.g. wpa)
--Armin
Re: svn co fails
On Fri, May 14, 2010 at 07:38:18AM -0400, Armin Steinhoff wrote:
> >> Thank you,
> >> Mark
> > Hello Mark,
wpa is dual licenced gpl / bsd.
Re: svn co fails
But you made it public, and possibly took public contributions, why go from non-transparent, to transparent, and then
back again?
If the source is going to be taken back like this, you guys could at least have advertised it a little more, I mean..
the only reference is some obscure "FAQ" which uses some weird terminology.
This is just sneaky and very unprofessional,
Please ask that a news article be published on QNX or foundry27 which gives a little more insight into this, maybe
telling people how the hell they're supposed to gain access to this rumoured revised "click-through" agreement for
'Accessible' code.
-BSDFan666.
Re: svn co fails
Thanks for the assistance.  After the legal department was satisfied with the form and associated agreements, I was able
 to download the restricted content.
But, now (and I might be asking this in the wrong location) I am not able to find:
lib/io-pkt
stuff.
I was able to download the whole trunk.  It has lib, but no io-pkt.
Any suggestions?
I have seen on the CVS pages that under cmmt27461 "- Make lib/io-pkt as a LATEDIR."
I see that in the Makefile, but cannot find lib/io-pkt.
Thanks in advance for any help,
Mark
RE: svn co fails
/trunk/lib/io-pkt/ is the right svn path. If you don't see it it probably means either of
1. the gate keepers of the source code have chosen not to publish it
2. the pusblishable version is in a different svn repository.
The legal guys you already have contact with, or possibly people in the Networking project would know where to apply to
get the source:
<http://community.qnx.com/sf/sfmain/do/viewProject/projects.networking>;
-ad
From: Mark Aubrey [mailto:community-noreply@qnx.com]
Sent: Tue 2010-08-31 12:21
To: osmeta-core_os
Subject: Re: svn co fails
lib/io-pkt
stuff.
Any suggestions?
Mark
OSMeta
http://community.qnx.com/sf/go/post65228
Attachment: Text winmail.dat 2.93 KB
Re: RE: svn co fails
Attilla,
Thank you for the prompt reply.
I was able to get it using:
Mark
