Forum Topic - checkout source through a proxy server:
I just tried to check out the coreos though a proxy server:
****@oekan227 ~/QNX
$ svn checkout --username ***** http://community.qnx.com/svn/repo
s/coreos_pub/trunk
svn: REPORT request failed on '/svn/repos/coreos_pub/!svn/vcc/default'
svn: REPORT of '/svn/repos/coreos_pub/!svn/vcc/default': 400 Bad Request (http://community.qnx.com)
Is this a server related error or a client error message?
Attached i post the ~/.subversion/servers file.
Attachment: Text servers 3.24 KB
Re: checkout source through a proxy server
Hmm. What happens if you use your web-browser on the url:
http://community.qnx.com/svn/repos/coreos_pub/trunk/
-ad
I cannot try it out, since I'm now at home. But I tried browsing the source from my iexplorer in the office and it
worked fine. I saw the subversion tree and code view the sourse of the dumper.
Perhaps I should play around with the proxy configuration in the servers file. Is there any change, that a wrong
protocol of http request/post... is selected?
/PIET
Fixed!
need to add next string in Squid config file:
extension_methods REPORT MERGE MKACTIVITY CHECKOUT PROPFIND
Your're lucky, that you can change the squid configuration. So, I will contact out IT to figure out, if they are willing
 to change the local squid configuration.
As searching for the solution from Yuriy, I got some hints, that SOCKS5 may be an alternative solutions. Seaching for
'svn socks5' did not points me to nay reasonalbe information.
Is there any good place known?
-piet
I have same error (REPORT ... 400 Bad Request).  Web interface working fine.
Using TortoiseSVN.
