Forum Topic - Commel LS-570 Problems Under QNX 6.4.1:
Platform: 	Commel LS-570
	QNX 6.4.1
Configuration:	2 out of 4 NICs enabled
		gma9xx video driver selected
		PS2 Keyboard & USB Mouse (would like to use usb keyboard but the stability on this platform is not acceptable at this
point - it was better under QNX 6.3.2)
Problem Description:
Having trouble booting consistently into Photon. More often than not I lose my mouse. In some cases I also lose the
network and in other cases I get a complete lock-up. I have been trying to diagnose the problem but I have not found
much to go on. I have tried disabling USB completely and using PS2 kbd & ms but even the PS2 stuff does not work
reliably. I have tried to increase the verbosity on the devu-[o,e,u]hci.so using -u "-v -dohci pindex=0,verbose=4 -duhci
 pindex=0,verbose=4 "  but I don't get much from them. I increased the verbosity on the network driver (drvnp-e1000.so)
and I noticed that I got a e1000: unexpected irq cause 0x1 - not sure if this is a problem????
Please help. Is there anything I can do to provide more information? If QNX is listening we sent one of these units to
you for custom driver development.
Thanks in advance,
- Richard
Re: Commel LS-570 Problems Under QNX 6.4.1
Follow-up:
CASE1:
1) Enable USB in BIOS
2) Generate network traffic
- on one or more remote nodes execute the following:
find /net/PROBLEM_NODE/usr
3) Machine dies within 10s
Notes:
- Same for i82544 or e1000
- USB and Network share interrupts
- USB triggers a PULSE on interrupt where as Network executes an isr
- i82544 generates massive ammounts of "unexpected interrupt (type 0x1)" slog entries
CASE2:
1) Disable USB in BIOS
3) No problems
I could live with CASE2 if my PS2 mouse worked under Photon but it seems it is not functional - any suggestions on how
to diagnose that problem? hidview sees it?
On Thu, Oct 08, 2009 at 08:13:47AM -0400, R Brown wrote:
> Follow-up:
> CASE1:
> Notes:
> CASE2:
> 3) No problems
As a first test can you try the current trunk
io-pkt from the networking project?
In my earlier days I would have loved to download and compile the source but now I am more of an end user. If you could
supply me with with a binary for the x86 platform I would be happy to try it.
- Richard
could supply me with with a binary for the x86 platform I would be happy to try it.
Here it is.
Attachment: Text io-pkt.tgz 1.3 MB
Tried the new io-pkt and I still have the same problems.
The system / network hangs when I issue a find /net/LS570/usr from a remote machine and I have USB enabled on the LS570.
 This is repeatable here and QNX has one of these PCs so they should be able to reproduce the same behaviour.
In the meantime I have disabled USB but the PS/2 mouse is not functional upon initial start of Photon. It seems I have
to exit to text mode and then relauch Photon to get the PS2 mouse working. I have added the following to the phapps file
 so I don't have to exit:
slay -f devi-hid
devi-hid mouse kbd
I will post the later problem in the appropriate forum.
