Forum Topic - Install a QPR file in command line: (3 Items)
I have a .qpr file and no access to the machine VGA port, so i can't start ph.
The OS is QNX 6.3.2 on an x86 machine.
Can I install this file remotely, with telnet ?
Re: Install a QPR file in command line
You should. You can call the command line qnxinstall to install it.
I want to install software remotely, so i can't use any graphic tool.
Here is the error :
# /usr/photon/bin/qnxinstall
Ap: Unable to locate Photon
