Re: java.lang.UnsatisfiedLinkError
03/09/2009 2:03 PM
post23932
Hi Hugo,
Please note: Ubuntu 8.10 is not officially supported platform in QNX SDP 6.4.0, so it has not been tested.
I did not see any installation issues on my Ubuntu 8.10, when launching the native executable. What was the error
message when you try launching .bin?
If you can also post /tmp/installOptionalLog.txt, that would be helpful.
Natalia
03/09/2009 4:15 PM
post23966
I have SDP 6.4.0 running on Ubuntu 8.10. Run the installer directly not the JAR file - that is likely causing the issue.
As far as I can tell, everything is running fine on 8.10.
03/09/2009 5:10 PM
post23975
Unless it is 64bit you can just run download and run (chmod +x first) linux installer directly.
Missing libraries message is caused by you trying to run this manually for some reason (why you running it from jar?).
Hugo Zeberg wrote:
> Hi!
> I have a problem installing QNX Software Development Platform 6.4.0 on my ubuntu distributio
> After I enter my license number i get the following message:
> "java.lang.UnsatisfiedLinkError: no qnxlic in java.library.path"
> It is not that I have turned on SeLinux, it is not even installed. I have tried with various version of Java. I use
ubuntu 8.10, and I'm installing via "java -jar qnx_linux_setup.jar"
> Using ./ on the bin file doesn't work at all (the java runtime environment doesn't start).
> Can I get around this issue?
> Best Regards,
> Hugo
> http://community.qnx.com/sf/go/post23866
