Re: How to install .qpr file
08/15/2009 12:26 PM
post36060
qpm is package manifest - you don't have to do anything with it (it is
an xml describing where files are installed if you would use special
utility to extract that). Qpr should contain other files which you
actually want to install (binaries,etc)
Andrew Smith wrote:
> I've also got a QPR file from a 3rd party (Quanser) I'd like to install. I have tried extracted the file but it
contains a bunch of QPM files that I'm not sure what to do with. I'd appreciate any help you can offer. Thanks.
> http://community.qnx.com/sf/go/post36043
08/17/2009 1:11 PM
post36120
First off, if you are using a version of Neutrino around 6.3.0 or earlier just use 'qnxinstall' to install it (see the
associated documentation). Otherwise read on...
The QPR format is really nothing more than a tar file. Within it are separate packages which are themselves tarfiles (*.
qpk) and description files (*.qpm).
If you untar the .qpk files you will notice a directory structure usually starting with a vendor name then a package
name and version (since it's a third party's file I make no assumptions about the layout). That means a couple of levels
in you will see a directory structure which is basically the root of the thing. Just copy those files to your
destination. There may be several packages so this should be repeated for each. It sounds more confusing that it really
is.
Cheers,
Keith Russell
