Forum Topic - QNX Momentics and Neutrino:
Hello, I just start to use QNX and I have some questions:
1. QNX Momentics is used for modify the Neutrino by programming on IDE? but it seems like Photon microGUI can aslo used
for programming. so what the difference between them?
2. if I just use Photon microGUI, this means I just need to install the Neutrino but need not to install the QNX
Momentics?
3. If I want to install a system which dual boots Windows and Neutrino, then I should use the "QNX Momentics Development
 Suite 6.3.2 - Neutrino Host" ?  IS this means neutrino RTOS have been contained in the suite, and I need not install
neutrino separately?
thanks very much,
Jason
RE: QNX Momentics and Neutrino
Hi, Jason.
Welcome to Neutrino. Here are some answers to your questions:
> aslo used for programming. so what the difference between them?
You can use PhAB (the Photon Appbuilder) to create graphical
applications that use the Photon microGUI. You lay out the user
interface, and PhAB generates the code that creates the UI and pieces
that you can attach the rest of your application to. PhaB runs on
Neutrino, but there's also a version that runs on Windows.
You can also use the IDE to create applications (graphical or not), but
it does a lot more too. You can use the IDE to build a boot image,
download applications to a Neutrino target machine and run them there,
profile your application, profile the entire Neutrino system, look for
memory errors, and more. You can even use the IDE to start PhAB on
Windows to develop a Photon application.
> install the Neutrino but need not to install the QNX Momentics?
In 6.3.2, the Neutrino version of Momentics includes a runtime Neutrino
system (i.e you get the OS, Photon, and the development tools). On
Windows and Linux, Momentics is a development system that you can use to
create programs to run on Neutrino (on a separate machine or in a VMware
session).
That's right. The Neutrino Host installer will create a new partition on
your Windows machine and install the Neutrino OS and the Momentics tools
there. If you want to run the IDE on Windows, you'll also need to
install the Windows Host version of Momentics.
I hope this helps.
Steve Reid (stever@qnx.com)
Technical Editor
QNX Software Systems
Re: RE: QNX Momentics and Neutrino
Thanks, it is really help.
