Re: Mysterious Boot Error Messages with Qnx Neutrino
08/14/2008 7:34 AM
post11775
Michael Dr. Haas wrote:
> I have a problem with new x86-Computers running Neutrino 6.3.2. In each
> boot process, the following screen text appears:
> ( ... BIOS messages ... )
> Press F1-F4 to select drive or select partition 1? 1
> Hit Esc for .altboot...........................................
> ..............Unable to allocate resource: Invalid argument
> ( ... no more output displayed for some Minutes ... )
> Press the spae bar to input boot options or D to disable DMA
> ( ... startup continues showing normal messages ... )
> The same was already showing when I installed Neutrino from the CD. As
> far as I understand the help in User's Guide Chapter "Controlling how
> Neutrino starts", something within the OS boot loader (Second stage boot
> loader) causes the message "Unable to allocat ..."
> In the BIOS, the Option "PNP OS" is already turned off.
> Can someone give advice?
This issue has come up in the past, but it was some time ago (around the
time of the last release) and
the issues had to do with the system allocation of data into the
internal (kernel) resource manager for
use by other programs.
* It might be a problem of a program called seedres that is used to seed
the system resources at
system start time. The problem might actually be caused due to the fact
that you have turned PnP
off since on x86
* The PCI manager pulls stuff out of the resource database to reserve it
for PCI use and then pushes
it back in as shared PCI resources. I don't know if it uses any PnP
information, but the main developer
for that monitors this forum and will likely chime in.
Not a lot of help unfortunately.
Thomas
