Forum Topic - QNX neutrino installation :
I have installed the Qnx neutrino in my system. when i open IDE and
work, the system is very slow, it takes around 10min to build. What may
be the issue. My system configuration,
ram - 512Mb
harddisk - 40Gb
processor - AMD processor
Note: i am using windows in  same system by partitioning
can u say what may be issue?? what would be better solution for it??
Regards
V.Murugadoss
We recently installed the spam filter from Abaca. It's over 99% accurate.
Check it out - http://www.abaca.com/promo.htm?domain=gdatech.co.in
Re: QNX neutrino installation
You indicated that it takes around 10 minutes to build. Could you please explain what are you building?
Please type
qconfig
and post the output.
Yuriu
Neutrino version of IDE is generally very slow because of problem with
underlining java implementation.
While we working on it, is recommended to use IDE on windows or linux
host and do cross platform compilation and remote debugging.
murugadoss v wrote:
> ram - 512Mb
> harddisk - 40Gb
> Thanks
