Re: QNX - Beaglebone Black - Unable to set the target in QNX Momentics
12/05/2016 5:02 PM
post117249
We tried to use the serial terminal several times but did not get any luck. We install the serial driver as in attached
image. Plugged the board in, power it up. Then we tried to use Putty to connect to it, nothing come up. We also tried
to use hyper terminal to connect to it with the same setting, the terminal responsed "Unable to connect to COM7, please
check your port setting"
That was why we decided to blindly write to command to uEnv.txt as the alternative solution. That was how we got a
little further with the Ethernet IP address with the hope that we can remote access to it or target it from QNX
Momentics. But we stuck again :)
Do you have any recommendation or suggestion for us?
