Forum Topic - I'm seeing popups with 'ctrl-v', etc. to click on to complete keystroke:
I wanted to change QNX Momentics IDE to use Visual Studio (hoping it would do things like ctrl-x to cut, etc, and ctrl-
shift-f to find in files.)
Now when I hit a control key chord, say, ctrl-x to cut, a little overlay in the lower right pops up with what it is, "
Cut", and the key, "ctrl-x".  I HAVE TO CLICK ON IT TO DO THE CUT.
If I go to a field, say, the search box field, and do ctrl-v to paste, it does the exact same thing.
At one time I did ctrl-shift-f to find, and it popped up two different things to choose from.  I suspect this "helpful"
feature turned on this, but it doesn't go off any more.
I changed the keyset back to default from Microsoft Studio and then also clicked the "reset keys to default" button on
the dialog, but target remains, Mr. President.  Target remains.
I am pulling my hair out of this "feature" as it gets in the way of key shortcuts by un-shortcutting them by inser oh I
give up.
How do I actually get rid of it?
Re: I'm seeing popups with 'ctrl-v', etc. to click on to complete keystroke
tl;dr I hit ctrl-c to copy, and a lil' yellow overlay pops up in the lower right corner of the IDE window.  I have to
click it to do the copy.
Make it go away so ctrl-c just does copy.
Hi Kevin,
Sorry to hear that you are having trouble. From what you are explaining this unfortunately looks like a bug in Eclipse
(which Momentics is built upon). Which version of Momentics are you using?
Creating a new workspace should solve all your problems, although that could be a lot of work depending on your
configuration.
Alternatively, you might have some success with the preference file: <workspace_location>/.metadata/.plugins/org.eclipse
.core.runtime/.settings/org.eclipse.ui.workbench.prefs
It contains all of the custom key bindings you've set (under the key org.eclipse.ui.commands). Have a look into there to
 see if there's anything that stands out (perhaps duplicate entries?) that could be cleaned up.
If you do decided to try and edit this file, before you do so please backup your workspace.
David
RE: I'm seeing popups with 'ctrl-v', etc. to click on to complete keystroke
Sorry, does not work.  I even deleted everything in that .settings directory, and it still happens after starting.  I
already have 3 workspaces, and it happens regardless of which I use (the other two I haven't used in months since long
before this began.)
So it must be some setting independent of workspace settings.
Best Regards,
Kevin
From: David Cummings [mailto:community-noreply@qnx.com]
Sent: Tuesday, August 18, 2015 12:44 PM
To: momenticsgs-community
Subject: Re: I'm seeing popups with 'ctrl-v', etc. to click on to complete keystroke
Hi Kevin,
configuration.
David
QNX Momentics Getting Started
http://community.qnx.com/sf/go/post114290
To cancel your subscription to this discussion, please e-mail momenticsgs-community-unsubscribe@community.qnx.com
Nothing in this message is intended to constitute an electronic signature unless a specific statement to the contrary is
 included in this message.
Confidentiality Note: This message is intended only for the person or entity to which it is addressed. It may contain
confidential and/or privileged material. Any review, transmission, dissemination or other use, or taking of any action
in reliance upon this message by persons or entities other than the intended recipient is prohibited and may be unlawful
. If you received this message in error, please contact the sender and delete it from your computer.
