Re: QNX 6.5.0 Corrupted File System (ALWAYS)
08/26/2013 11:30 PM
post104549
You must run dinit on the partition. You will see a /dev/hd1t79 which is the partition device.
Sent from my BlackBerry 10 smartphone on the Rogers network.
Sent: Monday, August 26, 2013 11:01 PM
To: momenticsgs-community
Reply To: momenticsgs-community@community.qnx.com
Cc: ricanz@san.rr.com; ricanz58@yahoo.com
Subject: QNX 6.5.0 Corrupted File System (ALWAYS)
I'm new to the forum and I thought I posted this already but I don't see my post added to the list, so hopefully this is
not a duplicate. I'm desperately trying to just create a QNX partition on a hard drive but I always get "Corrupted
file system detected". I've installed the QNX SDP 6.5.0 on my x86 Advantech PCM-9389 onto the primary SATA hard drive
via the SATA CDROM. I replace the CDROM with a new SATA hard drive. Then observe the new drive is mounted on /dev/hd1.
Then I:
1) fdisk -z /dev/hd1 to zero the partition table and enter interactive mode.
2) I change partition 1 to type 79, start at cyl 0, end at 4799, set the partition bootable, save, quit.
3) mount -e /dev/hd1
4) fdisk /dev/hd1 show this shows the drive as expected:
QNX type 79 start cyl 0 end 4799 size 37652 MB * (bootable)
5) I restart the system via "shutdown" command expecting QNX to automatically detect the new drive and partition and
mount it for me.
6) I see "mount: Can't mount /fs/hd1-qnx4 (type qnx4)"
"mount: possible reason Corrupted file system detected"
I have also tried manually mounting after step 4 via "mount -t qnx4 /dev/hd1t79 /fs/hd1" and I get the same error as in
step 6.
Please help and my apologies if this is a duplicate post. Thanks,
Eric Franz
QNX Momentics Getting Started
http://community.qnx.com/sf/go/post104544
To cancel your subscription to this discussion, please e-mail momenticsgs-community-unsubscribe@community.qnx.com
08/27/2013 1:05 AM
post104552
Thanks, that worked. Very grateful for your quick reply!
Eric
