Re: QNX Momentics Read Timed out ?
10/21/2010 10:15 PM
post71917
> Did you see qconn prompt?
> when you did
> telnet <ip> 8000
> Please post output here
> On 21/10/2010 9:55 PM, asdfasdf asdfasdf wrote:
> >> Do you have firewall? VPN?
> >> Try telnet to you target
> >> telnet<TargetIP>
> >> if it works try
> >> telnet<TargetIP> 8000
> >> On 21/10/2010 9:24 PM, asdfasdf asdfasdf wrote:
> >>> the QNX Momentics IDE 4.7 was installed usder the windows xp sp3 host, and
> >> the qnx rtos was intstall in then vmware 7.0 .
> >>> now , i am set the network to connect the host and the target,then they
> can
> >> ping each other. but when I use then QNX Momentics IDE to new a connect ,
> i'm
> >> failure,a tip "couldn't connect to taraget:read timed out" was called,
> the
> >> 'qconn' also was called in the qnx terminal. now somebody can help me ,
> thanks
> >> very much!!!!!!!
> >>> _______________________________________________
> >>> QNX Momentics Getting Started
> >>> http://community.qnx.com/sf/go/post71911
> > Thanks for your reply!
> > first of all , my windows firewall was closed and it not any vpn.
> > they can ping each other.
> > I'm do it as you say , the telnet command was executed normal.
> > any suggestion ? thanks!
> > http://community.qnx.com/sf/go/post71915
thanks for your reply !
I'm input then command " telnet 192.168.6.111 8000" in the windows cmd commandline , but it was not any result show .
the qconn was prompt int qnx vmware terminal.
| Attachment: |
20.2 KB
