Forum Topic - Cannot install QNX RTOS v6.4.1:
I've created a partion 20 GB and tried to install the QNX RTOS on it with the file sytem 179 with the option F1 QNX boot
 loader but I get this message "unable to access /dev/hd0t179"
whereas Installing QNX RTOS on the virtual machine worked quite fine.
thank you
Re: Cannot install QNX RTOS v6.4.1
More details about your hardware would be helpful. Also, how far did the boot process go - did you see the message "
Press space..." ? If so, have you tried to disable DMA from there?
Finally, now that 6.5 is out, give it a try. The hardware support was much enhanced with this version.
Let us know how it goes!
- Malte
