Forum Topic - Installing momentics on Windows Server 2003 64bit:
We have this really fast machine and I wanted to reduce my build times.
The installer won't run and reports the following:
java.lang.NoclassDefFoundErrpr: run
Exception in thread "main"
Any work arounds?  I'm betting it just plain isn't supported, but if there is a way....
Kevin
Re: Installing momentics on Windows Server 2003 64bit
Kevin,
Sometimes extracting java from native launcher and then using it to start the installer makes a difference.
Here are the instructions (replace "installerName.bin" with the actual installer name):
installerName.exe -is:extract
windows-sun-1.5.0.exe
bin/java -cp qnx_win32_setup.jar run
The last step can also be replaced with
bin/java -jar qnx_win32_setup.jar
Hope that helps,
Natalia
RE: Installing momentics on Windows Server 2003 64bit
Hey Natalia,
Thanks so much for the quick and detailed response.  I wish I could say it
worked however.  When I try the first method, namely: " bin/java -cp
qnx_win32_setup.jar run" I still get the same error: "Exception in thread
"main" java.lang.NoClassDefFoundError: run"
Then, when I try the second option ( bin\java -jar qnx_win32_setup.jar ) I
get: "Unable to access jarfile qnx_win32_setup.jar"
The file doesn't exist either...perhaps I've downloaded a bad image?
I'll try it on another computer...
Kevin
From: Natalia Miyusova [mailto:community-noreply@qnx.com]
Sent: March 26, 2010 13:58
To: momenticsgs-community
Subject: Re: Installing momentics on Windows Server 2003 64bit
Kevin,
installer name):
Hope that helps,
Natalia
QNX Momentics Getting Started
http://community.qnx.com/sf/go/post50605
Well, I tried it on an XP box and it looks like something happened to my
image.  It won't even run on an XP machine.  I'll re-download it...
Thanks for your help.
Kevin
Kevin,
installer name):
Hope that helps,
Natalia
