Forum Topic - Installer of DDK on Windows won''t find Java?:
I'm trying to install a DDK (character or input) on WinXP SP3 machine, where Momentics IDE 4.6 is already installed.
The Installshield setup scans all my disks (#$%^!)  looking for Java - and does not find a suitable version of Java.
Though, I guess, the IDE has some JRE version in it?
Then, I take a clean XP machine and install the latest Java (JRE 6 upd.17) from java.com. Again, Installshield can't
find it.
Then I run it in a command window:
> ddk-devc-6.3.0SP1-20043521256-win32.exe" -is:javahome "C:\Program Files\Java\jre6"
and again it does not take it.
Any clues, please? what Java version it needs?
S.
Re: Installer of DDK on Windows won''t find Java?
The installer for DDK requires java 1.4.2.  I would recommend downloading and installing  JVM patch (patch id #585) from
 our website.
Also, make sure you have QNX baseline installed before installing a DDK.
Natalia
> does not find a suitable version of Java. Though, I guess, the IDE has some
> JRE version in it?
> from java.com. Again, Installshield can't find it.
> \jre6"
> Regards,
> S.
Thank you, Natalia, it worked
(though not quite smooth. When I installed JRE 1.4.2 on my machine with Momentics, the DDK setup still was not willing
to accept it.
Had to install the IDE and JRE 1.4.2 on a clean machine).
Thanks again.
S.
